1995 xj died - JeepForum.com
post #1 of 6 Old 09-23-2013, 09:18 PM Thread Starter
dgood
1995 XJ Cherokee
1995 xj died
Started up my jeep to go home from work, went one block and it died. Just cranks but it won't start. Think it is a clogged fuel filter? It is original. Plugs and wires are new along with dist and rotor. Ran fine up till now. Will get it towed in the morning and try to figure something out.
dgood is offline
post #2 of 6 Old 09-23-2013, 09:31 PM Thread Starter
dgood
1995 XJ Cherokee
I have over half of tank of gas and I have only went about 90 miles on this tank.
dgood is offline
post #3 of 6 Old 09-24-2013, 08:07 AM Thread Starter
dgood
1995 XJ Cherokee
Got the codes this morning. Code 11 and 12. 11 is the cps so I checked resistance. Open across two pins and a short across the other two. Using the center pin as a constant in both measurements. Installing a new cps now. We will see how it goes.
dgood is offline
post #4 of 6 Old 09-24-2013, 08:56 AM Thread Starter
dgood
1995 XJ Cherokee
Changed out the crank positioning sensor and all is good. Started right up. I will give an update in a couple of days after driving it awhile and let you know how it is working out. Pretty easy to change out, 13 mm and a few extensions. 10mm for the bracket that holds it up on the intake. 70 dollar for the sensor. man.
dgood is offline
post #5 of 6 Old 09-24-2013, 09:18 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
$70 wouldn't have even got it through the door at most shops.
***Chris***
chris87xj is online now
post #6 of 6 Old 09-24-2013, 09:38 AM Thread Starter
dgood
1995 XJ Cherokee
Got lucky. Friend had AAA so the tow was only 12 bucks.
dgood is offline
