1995 Jeep Cherokee...just puked power steering fluid everywhere.. - JeepForum.com
post #1 of 11 Old 03-15-2008, 05:21 AM Thread Starter
Spanishfly
As usual, my wife was driving.. not her fault, but why does it never happen when I am behind the wheel?? Anyway, there is power steering fluid everywhere. So, I figured the best way to find where it was coming from, was to refill the pump, and start her up!! It came from the filler cap. It was very aerated, and the pump was making some strange noises.So...I guess I need a new pump...any comments or advice as to the best way to fix this, apart from a new pump?
Thanks
Nick
Spanishfly is offline
post #2 of 11 Old 03-15-2008, 05:44 AM
Crystalship1
Crystalship1's Avatar
I'm pretty sure they are generally non rebuild-able. I'd say a new one or one from a bone-yard.
Good luck!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #3 of 11 Old 03-15-2008, 05:51 AM Thread Starter
Spanishfly
Thanks!! errr...I think!
Nick
post #4 of 11 Old 03-15-2008, 07:08 AM
tcc9mpl
i thought id link my recent thread about replacing the power steering pump incase you might need it.
http://www.jeepforum.com/forum/f11/power-steering-major-leak-after-grinding-noise-527070/
Mods Surco Safari Rack 40''x60'' Baja Fogs K&N Air Filter
Audio Pioneer DEH-P7800MP headunit Infinity Ref. 311a Amp Infinity Ref. 1032w DVC Sub Rockford Fosgate 5.25'' TC120s
tcc9mpl is offline
post #5 of 11 Old 03-15-2008, 07:43 AM
conrasm
conrasm's Avatar
I'd replace the lines while you're at it. The high pressure line is about $20 at a parts store and the return line is just clamped on so you could probably get way with using a piece of tranny hose.
The high pressure line can be a PITA to get out of the steering box. I had to cut the metal line and use a socket to get it loose.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #6 of 11 Old 03-16-2008, 04:01 PM Thread Starter
Spanishfly
Thanks to you all!!great link there TCC9MPL!! Well, I took the pump off, and the bearing is worn..must have just suddenly quit. Easy job to get it off...not so easy to find a secondhand or cheap new one here in Spain They only imported the 4 cylinder diesel version, and that pump is different anyway..
Nick
post #7 of 11 Old 03-27-2008, 02:51 PM Thread Starter
Spanishfly
Got the pump rebuilt, put it on tonight, bled it..and bled it...and bled it..Started the engine, turned the wheel, and it screeches, when I turn the wheel. Not when the steering is in repose. Checked the fluid, and it was at the right level, but very aerated. I have left it to stand overnight, hoping it is just air in the fluid..
Nick
post #8 of 11 Old 03-29-2008, 12:50 PM
Tallpaul
I have almost the same problem except mine did not shoot fluid everywhere. 95 XJ, 4.0. Pump started whining, replaced it last night. I bled the system per the Haynes manual and got nothing but foamy fluid, stiff steering and more whining. The instructions with the pump said to disconnect the return line and spin the motor over, without starting, until clear fluid came from the return.
I cannot get any returning fluid at all. I am thinking the steering box is bad, any other advice?
Thanks
Tallpaul is offline
post #9 of 11 Old 03-29-2008, 01:50 PM
Tallpaul
Update: With the return disconnected and the engine runnig I get fluid from the return but it's still foamy and there seems to be no pwer assist at the steering wheel.
The pump is working as when I disconnect the pressure line with the engine running I get fluid.
Tallpaul is offline
post #10 of 11 Old 04-07-2008, 07:31 AM Thread Starter
Spanishfly
Sorry you are having this problem too. My pump was rebuilt, and I fitted it, filled it with fluid, and then bled it WITh the engine running first time, but without trying to turn the steering wheel.It started to work, but it was still very foamy. I left it overnight, to let the air all rise to the reservoir. When I went to look next morning,the liquid was clear, so I started her up, and turned the wheel. It still squawked and squeaked, but not so much, and the fluid became foamy again. So, I topped it up, started the engine, and taking about 20 seconds each time, I turned the wheel from lock to lock, about 5 times.Turned it off, and waited. Did it again 20 minutes later, and it was 90% ok. Then I drove the jeep for 10 minutes, and it just sorted itself out, and is now running perfectly. It is a biotch to get all the air out of the system, but it does in the end. patience is the key!
Good luck
Nick
post #11 of 11 Old 04-08-2008, 10:54 AM
Tallpaul
Thanks for the encouragement. I replaced the steering box and still have the problem. I have tried every method I can think of to get it bled. My thought was to try a second pump, but will try bleeding one more time.
Thanks
Tallpaul is offline
1995 XJ Cherokee, exhaust leak/power loss 221kJeep XJ Cherokee Technical Forum 0 10-02-2009 02:43 PM
what to use for power steering fluid mud-dog27 XJ Cherokee Technical Forum 4 05-15-2009 02:25 AM
Will a 1995 power steering pump fit a 1988? awysock1 XJ Cherokee Technical Forum 9 02-11-2008 04:58 AM
Steering box puked black2door XJ Cherokee Technical Forum 5 06-16-2007 09:08 AM
Power steering fluid XJ99 XJ Cherokee Technical Forum 8 08-31-2005 09:17 PM
