1995 Grand Cherokee Stalling when hot - JeepForum.com
post #1 of 1 Old 08-06-2012, 01:10 PM Thread Starter
s_staples35
Edited: Sorry, just realized this is Cherokee thread. Not sure how to remove..
My 95 Grand Cherokee is losing spark when hot..
The engine starts and runs great when cool. I can drive it for about 25-30 miles before it cuts out. I usually have to wait about 45 minutes to an hour before it will start again. Also noticed it is much better on the highway.
While it is "shutdown mode" with the key in the on position. I have recently noticed a buzzing sound in the transmission (possibly a solenoid) Not sure if this is telling the PCM to kill it or not, since this doesn't have a separate Trans control module.
ADS relay,TPS, and Fuel Pump, are all fine.
Prior to discovering this I have change the crank sensor (twice), cam sensor, coil (twice), distributor cap, rotor, all plugs and wires.
Any advice would be helpful. Love Jeeps... but this one's killing me
s_staples35 is offline
crank position sensor , ignition , intermittent , pcm , stalling
Help with intermittant stalling...97 Grand Cherokee iajet XJ Cherokee Technical Forum 6 03-26-2011 04:47 PM
1995 jeep grand cherokee MIKERPET XJ Cherokee Technical Forum 1 08-06-2010 09:30 PM
Does a 1985 Cherokee have the same bolt pattern as my 1995 Grand Cherokee?? 1995Cherokee XJ Cherokee Technical Forum 3 03-21-2010 06:48 PM
1995 Grand Cherokee Security Problem Snipew4 XJ Cherokee Technical Forum 2 07-17-2008 05:00 PM
1995 Jeep Grand Cherokee Engine Operating Temperature ChesterWilliams XJ Cherokee Technical Forum 5 03-21-2005 12:44 PM
