#1 | |
1994 Cherokee Death Shake
A few weeks ago, my 94 Cherokee developed the death shake. I rotated my tires thinking it could be a tire out of balance or worn issue and it didn't fix it. I took the stabilzer loose and it felt pretty tight. I checked tie rod ends and they looked tight. Bushings looked OK to the eye. What else could it be or how can the home mechanic diagnose it. It drives and rides fine till 50-55, then shakes horrifically. I think it might be bushings or stabilizer, but don't want to spend money there if not needed. Thanks in advance for any advice.
#2 |
copied and pasted:
Torque specs: Item ........................................ Ft. lbs. ................... Nm Lug nuts (1/2 X 20 w/ 60* cone) .... 85-115 .............. 115-150 All tie rod ends ............................ 55 ..................... 74 Steering (both ends) .................... 55 ..................... 74 Shock absorber upper nut .............. 16 ..................... 22 Shock absorber lower nuts ............. 17 ..................... 23 UCA frame end ............................. 66 ..................... 89 UCA axle end ............................... 55 ...................... 74 LCA frame end ............................. 85 ...................... 115 LCA axle end ............................... 85 ...................... 115 Track bar frame end ..................... 60 ...................... 81 Track bar axle end ....................... 40 ....................... 54 Track bar bracket bolts ................. 92 ....................... 125 Track bar bracket nut ................... 74 ....................... 100 Track bar bracket support bolts ...... 31 ....................... 42 Hub bolts (3) ............................... 75 ....................... 102 Hub- axle bolt .............................. 175 ..................... 237 Alingment specs (stock): Angle ............. Preferred ........... Range ............. Max R/L diff. Caster ............ +7.0* ........ +5.25* to +8.5* ......... 1.25* Camber ........... -0.25* ....... -0.75* to +0.5 ........... 1.0* Total Toe-in .... +0.25* ....... 0* to +0.45* ............. .05* Thrust angle .... 0* to ± 0.15* Check your Track Bar, play in this can cause the axle to shake. 1. Bushings - check to see that they are not worn. Looks for cracks, and excessive play) 2. Angles - this angle should be the same as your draglink. Use an angle finders you can get at sears to determine this, don’t just eye-ball it. 3. Bolts – Make sure all bolts are tightened down to spec (some lift components have a different torque spec then) Check the Axle, your mounts may be worn 1. Check the axle mount. Here is a good write up on a wallowed out bolt hole http://www.jeepin.com/features/trackbarfix/index.asp 2. Check your Universal joints, a binding or lose U-Joint can cause DW 3. On the frame end if you still use the conventional Tie Rod End or (TRE) make sure that there is no play in this, as play can cause DW. 4. Look/Check for worn/torn boots on ball joints/tie-rod ends. Check your Tires 1. Out of balance tires can cause shaking in the front end, which can lead to death wobble. 2. Make sure all of your lug nuts are tight, (Sounds elementary but it happens to the best of us) Check your Frame 1. Small cracks in the frame can cause the steering box to feel loose, Shaking from DW can only make this worse. 33’s and larger should have some form of Steering box brace, or frame brace in. 2. If you have upgraded your frame mount, make sure its cranked down nice and tight. (best to use an impact gun) 3. A busted Frame Mount can cause play in the front end causing DW (Keep a watchful eye on the welds as welds in sheer can break over time. Make sure you have a good alignment 1. After you get an alignment done, have them print out the numbers for you. An XJ should have a 7* positive caster angle. A lifted XJ can’t always have that high of a number because the pinion would become out of alignment with the front driveshaft. Pinion angle takes precedence over caster. 2. Make you sure you go to a place that will adjust the caster if necessary (either by shims in the frame side of the LCAs, or adjustable LCAs). The more adjustable parts the easier it is to tune in your suspension. 1. Adjustable Track Bar 2. Adjustable Upper and Lower Control Arms (upper ones above 4” of lift). Not only are they adjustable, but they are stronger. Things to remember: 1. A Steering Stabilizer (SS) is not a quick fix for DW. Entire list of everything that can cause death wobble: -Front tires out of balance -Front alignment out of spec -Loose track bar -Worn track bar bushings -Worn track bar end -Need adjustable track bar -Bad bushings/joints in control arms -Worn/damaged steering stabilizer -Worn/damaged shocks -Worn/damaged tie rod end -Bad U Joint -Bad ball joint -Loose frame mount -Steering box looseness -Need drop pitman arm -Driveshaft(s) not balanced -Bad front hub assembly |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
