1992 XJ RKE (Keyless entry) upgrade: IR to RF (OEM) (OMG)!!! - JeepForum.com
post #1 of 12 Old 12-20-2010, 04:16 PM Thread Starter
ryder267
1992 XJ Cherokee
Ah, hahaha! I did it! I successfully integrated an OEM RF keyless entry receiver into my 1992 Cherokee Laredo. (A little cheating was involved but I believe it to be more or less authentic )
SO, for those of us who own an XJ Cherokee --with power locks, of course-- built between 1987 and 1996, we are familiar with the dreaded infrared key-less entry remote and dome receiver. Originally an accoutrement of the Renault, the system was awesome in its heyday, but certainly lived long into functional obsolescence; its inefficiencies and restrictions are ones that could have been designed out, but this process was long and slow for some reason.
When I bought my 1992 Cherokee Laredo, half of the reason I did so was because it still had its working --original-- one button "Neiman" key-less entry remote!! A horrid system though it was, I was swayed by the novelty of having it; I don't think I had ever even seen one in real life before that day. Everything was cool until the remote finally bit the dust. An internal chip broke free from the circuit board; I tried to solder it, but ruined the transmitter in the process.
After my loss and subsequent period of grieving, I decided that I was going to have a "new" key-less entry system. Being a hard-core Jeep man, however, I resolved that the system that was going into my car was going to be a "Jeep" one; there would be no aftermarket crap in my baybay.
Thankfully 1992 was the last year of the "single button" "dealer programmed"
remote, and with the 1993 model year came an upgrade to a "dual button" "me programmed" remote; it was still IR, though. GRRRR. I figured that my '92 XJ, being on the cusp of this change, would probably support a 1993 RKE system with relative ease of integration and minimal pain of re-engineering. I was right. I successfully installed an IR system from a donor 1996 XJ Sport into my '92. It was nice to finally be able to choose between lock and unlock, and also to be able to program the remote transmitter myself without having to deal with the dealer$. (For those who may be interested, it isn't actually that hard to do for the 1990-1992s. The 1989 and priors are trickier, however. I've not successfully done one yet, but I can visualize most of the system and I don't think it would be impossible.) The only downside to my upgraded system, of course, was that it was still IR. I had to have the damn remote up against the window, pointed at the receiver as closely as possible in order for it to work.
LOOKING FOR A BETTER SOLUTION, I started checking out sites to see if anyone had successfully integrated an OEM RF system into one of the pre-1997 XJs or pre-1996 ZJs. So far, there's no info. One thing I certainly learned was that one is absolutely disallowed from programming his/her own remote with these post 1996 RF systems; subsequent lessons would teach me that it is effectively impossible. Thanks Chrysler.
Feeling confident in the beginning, despite this obstacle, I purchased a receiver --extracted from a 1998 XJ Limited-- from the junkyard. I also picked up two transmitter remotes, one from a 1996 ZJ (shaped like a rectangle), and one from a 1999 WJ (shaped like an "8"), both were tested and functional; I figured that one was bound to work. After mapping out the wires and doing extensive kamikaze engineering, the system was remained to be a no-go. It's safe to say that the DRB scan tool is, in fact, mandatory to program these stupid systems. My Jeep, not being equipped with an OBDII port, leaves me screwed. Fabulous.
NOT GIVING UP IS A VIRTUE. During my research, I noticed how the 1996-1998 rectangular remotes are very similar in design to those of GM automobiles of the same time period.
I learned that both Chrysler and GM cars --for a brief time-- shared a RF system produced by "TRW Automotive."
After a bit of research, I determined that this system is not only compatible with Jeeps, but it's also simple to install, and best of all, allows one to program his/her own remote(s)!! Of all of the GM cars, I determined that the best system to recover is one from a 1993-1995 Chevrolet Camaro or Pontiac Firebird (it's the same car). The RKE module is located right under the passenger's side kick panel. There is also a wonderful website that I must give credit to for having assisted me with this. It lays out a complete and accurate wiring schematic for the system. <http://berlinetta.info/KeylessEntry.htm>
The RKE module I used in my Jeep was removed from a donor 1994 Firebird. The new module is beefier than the IR "Jeep" one I took out of my overhead console, so I moved it to a space underneath the passenger's side dashboard next to the TCU. It fits snug. This is also a good place for it, because all the wires needed to connect it are underneath the passenger's side kick panel. Bearing in mind that this application was specific to a 1992 XJ; other applications may have different wire color codes. The wiring is as follows.
On the Jeep Side On the TRW module side
Pink (power)--------------Orange
Black (ground)------------Black
Blue/red (dome lights)-----White
Orange/purple (lock)------Gray
Pink/purple (unlock)-------Tan (there are two tans use only one)
Orange/black (do not use)
Red/black (do not use)
Pink/black (do not use)
Black ("Panic" or "Trunk Release" not equipped.)
Black/white (ground for remote programming mode)
Programming mode:
Once the module is installed, turn the key ignition to "ON" but not "RUN." Ground the Black/white wire. Within a few seconds the door locks will cycle. press and hold BOTH "lock" and "unlock" buttons on the transmitter. The locks will cycle again if and when the remote is accepted. Program any other remotes at this time, this way, as well. Once the ground is removed and the key ignition is turned "OFF," the transmitter data will be stored in the receiver. If the wire is re-grounded, all data will be lost and the remotes will need to be reprogrammed.
Remember that 1996 ZJ remote I purchased? I was able to program it directly to this RKE module! This means that the remote I'm using is a genuine "Chrysler/Jeep" RF remote which now operates the key-less system in my 1992 XJ! (the remote even has a "Chrysler" logo on it!)
Sweet!!
Also, that 1999 WJ remote I mentioned earlier is not compatible with this system. I tried to program it and it didn't take; this despite also being a TRW Automotive product(!)
So there ya have it!
Anyone can now have an "official" Jeep RF RKE system in his/her pre-1997 XJ! My remote now works up to about 20 feet away and I don't need to be pointing it at the car.
Awesome!
ryder267 is offline
post #2 of 12 Old 12-20-2010, 04:47 PM
justanotherjpr
Wow, nice work.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 12 Old 12-20-2010, 05:06 PM Thread Starter
ryder267
1992 XJ Cherokee
Thanks man! I'm walking on sunshine at the moment.
A lot of people told me that this could not be done. (That's what they also said when I embarked upon the first upgrade).
I win. Lol.
ryder267 is offline
post #4 of 12 Old 12-20-2010, 07:02 PM
mp15dc
1989 XJ Cherokee
Thats some good info. Well done.
I will have to try that in my 89 next year.
mp15dc is offline
post #5 of 12 Old 12-20-2010, 07:36 PM
Azzy
Cool writeup!
Now, who can figure out how to get us one of those snazzy keys with the fob built in?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #6 of 12 Old 12-20-2010, 09:30 PM
Holder350
1995 XJ Cherokee
Pretty cool....but for the trouble I would have gotten one of these.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #7 of 12 Old 12-20-2010, 09:32 PM Thread Starter
ryder267
1992 XJ Cherokee
Well, if you go the RF route for pre-1990 models, I know for sure that it's possible.
I think the that key-less entry system consists of four wires.
pink - power
black - ground
tan - unlock (maybe lock, not sure)
green - lock (maybe unlock, again, not 100% sure)
The fifth wire for the dome lights is not totally necessary.
You can always go aftermarket, but then you loose the "Jeep" panache you get from having a Chrysler remote.
Good luck! :-)
ryder267 is offline
post #8 of 12 Old 12-20-2010, 09:39 PM
Holder350
1995 XJ Cherokee
I'v had my $30 RF box under the dash for about 3 years now...I drew one of these on it....
post #9 of 12 Old 12-20-2010, 09:41 PM Thread Starter
ryder267
1992 XJ Cherokee
Fair enough, too.
The idea for my project, however, was for those who wish to keep the "Jeep" appeal to their key-less entry remotes in particular.
It's also no trouble at all --a very simple system to install.
And as far as cost, I got the remote for free, but eBay sells them from starting at a few bucks. The module cost $13 at Pick-N-Pull, and you KNOW that there is a glut of Camaros and Firebirds at the junk yard; I had my pick of 5 different cars today. I mean, who would have ever thought to look at a GM product for a solution? lol
Ultimately I was just happy that I found a way to circumvent Chrysler protocol and have my OEM RF transmitter.
ryder267 is offline
post #10 of 12 Old 12-20-2010, 09:46 PM Thread Starter
ryder267
1992 XJ Cherokee
Again, its about the remote, not the receiver.
The receiver doesn't matter, it just needs to work.
ryder267 is offline
post #11 of 12 Old 12-20-2010, 10:07 PM
sbxj
sbxj's Avatar
Jeep appeal
I have the newer OEM remote and it's still a joke...works on occassion and not very good distance at all.
I can appreciate your DIY attitude but why not save it for something useful?
I guess it looks cool to have "Jeep" on my remote but I'd rather have a good aftermarket car alarm with more options and better range.
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #12 of 12 Old 01-05-2012, 02:42 AM
joakimsr
1995 XJ Cherokee
Great writeup, just what im looking for, so now im trying to locate someone that ships to Norway.
Thank you
Edit:
It is now installed and working in my '95 XJ! Except the drivers door of course, as there seems to bee something wrong with the electric locking on that door, havent noticed it until now as i used a key. Will have to do something about that some time...
But thanks again for the writeup!
There was one cable different on mine:
Jeep - TRW
Purple (Ground) - Black
joakimsr is offline
Remote Start and keyless entry. or just keyless entry? racerdude_9 XJ Cherokee Technical Forum 5 02-26-2009 10:18 PM
Keyless Entry dajeepman XJ Cherokee Technical Forum 11 10-27-2006 11:51 AM
Keyless Entry SlimGoaty XJ Cherokee Technical Forum 4 01-17-2006 12:50 PM
keyless entry? if you have power options, doesnt it automatically have keyless? Xride XJ Cherokee Technical Forum 9 11-10-2005 01:47 AM
wanted keyless entry 1992 schreckman XJ Cherokee Technical Forum 3 07-06-2002 07:52 AM
