1992 Jeep Cherokee won't start! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 1992 Jeep Cherokee won't start!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCORRough Country Lift Kits and Parts!
Unread 02-15-2011, 01:31 PM   #1
PoorJeepGuy90
Hi! I have a problem. My 1992 Jeep Cherokee Sport won't start up. I turn the key and i hear the engine try to start, then it will just click in the engine. Basically, it sounds like 'wreer wreer wreer click click click click click." Best way I can describe it, ha ha. My dad and I took the starter out and got it tested, and it worked just fine. We also took out a weird looking piece that was near the battery. It was connected to a red wire that goes from one end of the engine to the other. It looks like 2 small rectangles on a flat piece of plastic and 4 screws on the bottom of it. Its only about 2"x2"x1 1/2" or so. What is also weird is that after we put the starter back on the Jeep, we tried to start it up and it worked! But i tried this morning and it did the same thing. What we are most curious about is the little piece that's really corroded. Can someone help me out please? Its only got 139k miles on it, and I really depend on this Jeep.
PoorJeepGuy90 is offline   Reply With Quote Quick reply to this message
Unread 02-15-2011, 01:49 PM   #2
Mikeand
Did you clean up the connections on the starter and battery? It is the problem 90% of the time. Clean all the grub and grime off till they shine, on the starter and on the cables.
No idea what part your talking about, pics speak a million words
1996 Cherokee Sport -4.6L Stroker, TB Spacer, Cold Air Intake, APN Header - D30 front / 8.25 Rear -RC 3" Lift -Dakota Leaf Pack -Rough Country Discos / -31" General Grabber A/T2s on 15x8 Cragar Soft 8s -Diamond plate rear quarter panels -Front bumper with hoop - IRO Double shear Track Bar and HD tie rod -Homemade light bar
Mikeand is offline   Reply With Quote Quick reply to this message
Unread 02-15-2011, 10:27 PM   #3
PoorJeepGuy90
Actually, I went to Autozone and got a new battery and it fired right up! It was just really damaged. I'll take a picture later of the piece I'm talking about.
help needed , start problems , starter issue , starting issue , won't start
