1992 Cherokee Sport Starter - JeepForum.com
post #1 of 9 Old 06-11-2007, 09:00 PM Thread Starter
muldoon
2008 WK
Have a starting issue. Turn the key and you hear the starter solenoid engage but starter does not turn. Do this 3 or 4 times and the starter comes to life and the engine starts. Swapped the battery out for a known good one, same issue, so changed the starter. Same issue. Turn the key and you can hear the solenoid engage but starter does not turn. No major draw off the battery. Checked the gound connection and all appears OK. Replaced the positive battery lead connector. Still no joy. Not a tough system. Any thoughts ?? 1992 Cherokee Sport, 6 cyl, 4.0, no air con.
muldoon is offline
post #2 of 9 Old 06-11-2007, 10:12 PM
Goldenknob
2007 WK
check all your ground connections on both ends of the wires... was my problem when I wasn't getting a start. I had a loose ground connection on my engine block to battery cable.
Goldenknob is offline
post #3 of 9 Old 06-11-2007, 10:22 PM
captain_ruggy
captain_ruggy's Avatar
1994 XJ Cherokee
Are you sure the starter is any good? You may have replaced a bum starter with another one. it does happen sometimes. Do you have any parts stores near by that test them?
1994 Jeep Cherokee 4x4
4.0 HO, Auto, 4dr., NP231, 8.25 rear
6 inches of bastard pack lift, 35/12.5/R15's
Aux. fan switch, homemade BPE's
moved intake, OEM towhooks
Rear disc brakes, JKS disco's
captain_ruggy is offline
post #4 of 9 Old 06-11-2007, 10:48 PM
Jmila1901
Jmila1901's Avatar
Autozone checks starters!
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #5 of 9 Old 06-11-2007, 10:49 PM
gradysjeep
gradysjeep's Avatar
VIP does too in my area.
gradysjeep is offline
post #6 of 9 Old 06-11-2007, 10:54 PM Thread Starter
muldoon
2008 WK
Thanks for the replys. The new starter was a Bosch unit. Brand new, not a rebuilt. Guess that's the next step. Already checked the battery ground at the engine block and it was / is good. Seems funny I would get the same issue with the old and the new starter though.
muldoon is offline
post #7 of 9 Old 06-13-2007, 04:00 PM Thread Starter
muldoon
2008 WK
Ground Strap
Anyone know where the engine to frame ground strap is on the 1992 Cherokee Sport ?? Could be my problem.
muldoon is offline
post #8 of 9 Old 06-13-2007, 04:34 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
well on my 1990 its on the firewall a little to the right of the valve cover, not too hard to spot the flat wire.
1990JEEPXJ is offline
post #9 of 9 Old 06-13-2007, 05:56 PM
Goldenknob
2007 WK
ya, it's on the back of the engine at the firewall behind the valve cover.
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 06:29 AM
Basic questions re. transmission fluid, 1992 Cherokee Sport monumentalfolly XJ Cherokee Technical Forum 2 02-20-2009 07:22 PM
1992 Cherokee dirt XJ Cherokee Technical Forum 1 02-11-2006 08:15 PM
1992 Cherokee Sport A/C atsoca XJ Cherokee Technical Forum 2 07-04-2005 06:46 AM
