1992 Cherokee Laredo Rear Axle Alignment? - JeepForum.com
post #1 of 7 Old 01-30-2011, 10:38 AM Thread Starter
daffy
I just installed a Rough Country 3" lift kit on my 1992 Cherokee Laredo. This kit included front and rear shocks, front coil springs, and rear leaf springs. Everything seemed good until I mounted my new bigger tires. I noticed the rear drivers-side tire is almost touching the rear of the wheel well. The passenger side is aligned in the center of the well as expected.
The axle appears to be U-bolted correctly with the pin on the leaf in the hole on the mount. I noticed while doing some rough measurements that the rear leaf springs are manufactured different and the distance between the axle and the front and rear mounts is slightly off.
1. Is there a front and back direction for mounting the springs or does it matter?
2. Can the alignment be adjusted?
3. Any suggestions on how to fix this without modifying the wheel well?
Thanks in advance!
daffy is offline
post #2 of 7 Old 01-30-2011, 10:40 AM
93gc40
Hang the rear spring in the correct dirrection. Or the locating pins have slipped. there is NO alignmet adjustment for the rear. Something is instaled wrong.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 7 Old 01-30-2011, 10:41 AM
93gc40
Short end of the spring to the front.
93gc40 is offline
post #4 of 7 Old 01-30-2011, 12:37 PM Thread Starter
daffy
Thanks everyone for the quick responses. Both ARE installed in the correct direction. However, the springs are assembled differently. The side with the correct wheel alignment has the straps which rap around the individual springs but the incorrect side does not have these. Also, one spring has rounded end on each spring element while the other's is square. I also measured from the rear mounting bolt to the back U-bolt thread (only method I could think of to get a strait line measurement) and one side is 26" and the other is 26 1/2". I'm thinking they sent me the wrong spring.
1. Any ideas?
2. Where can I find the part number on the springs? I couldn't see any from underneath. I figured my next step would be to call Rough Country but they are not open on Sunday.
daffy is offline
post #5 of 7 Old 01-30-2011, 02:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I think it would be correct to assume that you got 2 different leaf springs and the one of them is incorrect for an XJ. Calling RC with your concerns and measurements should be your first step.
CALL RYAN AT 1-800-222-7023 EXT 123
CJ7-Tim is offline
post #6 of 7 Old 01-30-2011, 03:21 PM
Yucca-man
Give them a call - the measurements won't necessarily match up since you've got weight on the pack, but they should be the same side-to-side. You might find the part number on the top of the pack - a lot of manufacturers will spray-paint it on in that area.
Yucca-man is offline
post #7 of 7 Old 01-31-2011, 09:30 AM Thread Starter
daffy
Well good news and thanks to CJ7-Tim. Ryan at Rough Country agreed that I had the wrong spring and is sending out a replacement at no charge. I would have to say that Rough Country's and National Tire & Wheel Online's customer service is awesome.
daffy is offline
lift advice , lift kit advice
1992 laredo door hinge pin broke...how should I fix it a5tach XJ Cherokee Technical Forum 0 02-28-2009 11:40 AM
Cold Air Intake On 1992 Laredo Skimboarder XJ Cherokee Technical Forum 12 09-06-2008 08:19 PM
1992 cherokee laredo speed/tach/fuel gauges not working? ChucksJeep XJ Cherokee Technical Forum 0 02-24-2008 08:12 AM
1992 Cherokee Laredo Frost Plug Meatroach XJ Cherokee Technical Forum 4 08-19-2004 10:41 PM
Rear axle in 91 XJ Laredo? exc911ence XJ Cherokee Technical Forum 4 08-16-2004 01:24 AM
