1992 Cherokee Laredo AUX fan only turns on with a/c? - JeepForum.com
post #1 of 3 Old 05-16-2013, 02:28 PM Thread Starter
MikeyJ
Hi all,
Been having some warmer weather here in Colorado and was driving around and noticed the jeep was running hot. Between 210 & 230. Only was getting hot when sitting at a light. Long story short the Aux cooling fan only comes on with the a/c on. It won't come on when the jeep is getting hot. If im not mistaken it should. So what controls the on/off of the aux fan with excessive temp?
1992 Jeep Cherokee Laredo
4.0L Inline 6
Automatic
MikeyJ is offline
post #2 of 3 Old 05-16-2013, 03:02 PM
Paradise XJ
1988 MJ Comanche
On your 92 the temp sensor in the thermostat housing tells the computer to turn the fan on.
If you unplug it, the fan should come on...if that happens, replace the sensor.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 3 Old 05-16-2013, 07:47 PM
Rosati21
1994 XJ Cherokee
and when you unplug the ect the check engine light will come on so after you figure it out unhook the battery for 30 min to reset KAM(keep alive memory) which will reset fuel trims and idle so when you start it up have the A/C off so it relearns the idle with out the load or else when the A/C kicks on it might die or idle too high.
Rosati21 is offline
