1991 XJ GasTank Mod +5 gals - JeepForum.com
post #1 of 4 Old 05-10-2013, 12:20 AM Thread Starter
Diamond-x
1991 XJ Cherokee
Anyone done this? I've read about and wonder if the air pocket is there for a reason. Is it a true 5 gallon addition? Any gotcha's?
Thanks!
Diamond-x is offline
post #2 of 4 Old 05-10-2013, 12:21 AM Thread Starter
Diamond-x
1991 XJ Cherokee
I should clarify, it involves trimming the breather tube which is inserted in the tank. Thanks!
post #3 of 4 Old 05-10-2013, 11:31 AM
Crewdude007
What, me worry?
What mod? Is there a link?
Currently Jeepless
2001 XJ - SOLD
2000 WJ - SOLD
Crewdude007 is offline
post #4 of 4 Old 05-10-2013, 11:51 AM
Project1
Thanks!
Yes .. I almost did this .. but when I read about it .. the reason there is extra room in the tank is because when the temp of the gas changes the actual fluid and fumes both expand. The extra room is to support this expansion. If you re-vent the tank this can be a safe mod, but IMO it was not worth it. I thought about getting a 15 gallon fuel cell with a pump, just to refill my stock tank, if I needed to carry more gas.
GO jeep has a good write up on this
All is you do is put an "j" shaped tube on the fill hole inside the tank .. the mod cost $2 and does make room for more gas however.
Project1 is offline
