1991 transmission wont shift in proper gear - JeepForum.com
post #1 of 7 Old 01-25-2009, 08:34 PM Thread Starter
corbin9191
I have a 1991 jeep cherokee laredo with a 4.0 liter. I was having trouble with the old transmission when I bought it so I just switched the trannie. But the problem that I am having with it right now is when I go and put it into drive it automatically shifts into 3rd gear, and when when stomp on the gas it will not go into the passing gear and overdrive wont work. Any suggestions? Thank you
corbin9191 is offline
post #2 of 7 Old 01-26-2009, 09:39 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What problems did you have with the old transmission ? Did you adjust the Transmission cable on the throttle body ? Have you tried a different Transmission Control Unit (TCU) ?
The automatic transmission cable may need minor adjustment for proper operation.
Early model JEEPS have a clip on the transmission cable sleeve were it snaps onto the support bracket.
Pull the clip up with a small Flathead screwdriver, feed the slack in the cable into the sleeve and
push the clip back down to lock the adjustment in place.
Late model JEEPS have a half round push button cable lock. Push the half round button located
on the back of the bracket near the throttle body and push some of the cable into the sleeve. From
the drivers seat, with the engine OFF, push the gas pedal all the way to the floor.
You may have to adjust the automatic transmission cable a couple of times for correct transmission operation.
CJ7-Tim is offline
post #3 of 7 Old 01-26-2009, 10:58 AM Thread Starter
corbin9191
The problems that I had with the old transmission is the bands were going out of it. I have tried to adjust the transmission on the throttle body and it didnt do anything for the trannie. But the thing that I didnt try yet was to replace the TCU. But I will try that next. How much do they cost usually?
post #4 of 7 Old 01-26-2009, 11:00 AM
CJ7-Tim
CJ7-Tim's Avatar
www.car-part.com
CJ7-Tim is offline
post #5 of 7 Old 01-26-2009, 03:47 PM Thread Starter
corbin9191
Well I switched my old TCU with one out of a 89 jeep and the trannie is finally shifting, but there is not over-drive. Does anyone know how to fix that? And how do you buy off of that site? Thank you
post #6 of 7 Old 01-26-2009, 08:24 PM
CJ7-Tim
CJ7-Tim's Avatar
I called one of the junkyards and they shipped me a part. Make sure you can return or exchange if the part doesn't function correctly.
CJ7-Tim is offline
post #7 of 7 Old 01-27-2009, 11:11 AM Thread Starter
corbin9191
Ok, becuase I took my old TCU out and look inside and the whole board burned up and there were scorch marks all over the case. But I will give them a call and see if they still have that part.
Cold transmission wont shift out of 1st gear sAe23 XJ Cherokee Technical Forum 38 07-01-2013 06:51 PM
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 11:51 AM
wagoneer LTD. wont shift into gear from park Cefalak XJ Cherokee Technical Forum 2 01-25-2010 11:10 PM
Automatic transmission wont shift automaticly for_givn XJ Cherokee Technical Forum 3 12-04-2009 05:01 PM
Transmission acts like it won't shift out of 4th gear 53case MJ Comanche Technical Forum 0 11-01-2009 09:52 AM
