1991 jeep cherokee wont start when hot - JeepForum.com
post #1 of 11 Old 08-16-2010, 01:01 PM Thread Starter
shane123456
1991 FSJ Cherokee
I got a 91 jeep cherokee with 196,000 miles. Its ran fine until about a month ago . it starts fine but after i've drove it and it heats up it wont start the next time until i let it cool down for about 10 or 15 min.
Any ideas anyone?
The engine cranks fine when its hot, but its almost like it doesnt get fuel until it cools down
shane123456 is offline
post #2 of 11 Old 08-16-2010, 01:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Fully describe the no-start symptoms. What does it do or not do, what do you hear, what do you see on the dashboard gauges ?
CJ7-Tim is offline
post #3 of 11 Old 08-16-2010, 02:29 PM
Mkonyn
x2 on more info.
IF it's something obviously thermal/heat related, which generally means computer/sensor, it could possibly be the CPS. Test CPS connector's leads with a volt meter that has an ohms setting. I think you should have a CPS resistance of between 120-280 ohms (I could be off, someone verify?).
Does it push fuel or try to crank when trying to start hot?
Mkonyn is offline
post #4 of 11 Old 08-17-2010, 03:00 PM Thread Starter
shane123456
1991 FSJ Cherokee
91 jeep cherokee
It cranks perfectly fine when its hot, but it seems as if its not getting fuel until it cools down
post #5 of 11 Old 08-17-2010, 03:03 PM Thread Starter
shane123456
1991 FSJ Cherokee
91 cherokee
it cranks fine when hot, but it seems like it doesnt get fuel till it cools down
post #6 of 11 Old 08-18-2010, 03:15 AM
CJ7-Tim
CJ7-Tim's Avatar
I suggest testing or replacing the Crankshaft Position Sensor.
The most likely cause of it cranks and cranks but won't start up is the Crankshaft Position Sensor (CPS) located on the transmission bell housing. Often this part is also referred to as the CranKshaft Position Sensor (CKP) CPS/CKP failure is very common. The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again (and will test as “good”) when it cools back down.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. Jeeps do not tolerate low voltage or poor grounds and the ECM/ECU may behave oddly until you remedy this.
Symptoms –
- Starter cranks and cranks but engine won't start up and run.
- Fuel gauge and voltage gauge may not work or display properly.
- You sometimes will have No Bus on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- No spark at the spark plugs.
- Fuel pump should run and prime for 3-5 seconds.
If the CPS/CKP is failed sometimes the OBD-II trouble code reader cannot make a connection to the ECU/computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed. Disconnect the code reader, disconnect the CPS/CKP wire connector, and reconnect the code reader. If the code reader establishes contact with the ECU and scans, your CPS/CKP is failed and needs to be replaced.
Diagnostic steps to confirm the CPS is the cause of your no-start
You should be able to verify a bad cps, by unplugging it, and turning the ignition key to on. If the voltage gauge and/or the fuel gauge now displays correctly and/or the No-Bus is gone, replace the CPS.
Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate the relays as the cause of the no-start. Check the ASD relay fuse.
Confirm that the fuel pump to runs for 3-5 seconds when you turn the ignition key to ON.
Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start. Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will loose communication. Don’t get tunnel vision and assume the sensor is bad (unless it tests bad with a meter). Damaged wiring or a dirty connector can inhibit the signal from making it to the computer. Inspect/test/clean/repair wiring or connectors as necessary.
CPS Testing
Crankshaft Position Sensor Connector (CPS/CKP)
TESTING PROCEDURE 1991 – 2001 4.0L H.O. engines
1. Near the rear of intake manifold, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter across terminals B and C (See Image). Ohmmeter should be set to 1K-to-1OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCECURE for 1987 – 1990 4.0 L engines
Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 – 275 Ohms. . If the CPS is out of that range by much, replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector may be on the passenger side, not as shown in the diagram below. Simply follow the wire from the sensor to the connector.
If this information has been helpful, please click on the "thumbs up" icon on the bottom right side of this section.
CJ7-Tim is offline
post #7 of 11 Old 08-18-2010, 09:22 AM Thread Starter
shane123456
1991 FSJ Cherokee
only when hot
even though the onlyy time it wont start is when it is hot?
Symptoms –
CPS Testing
post #8 of 11 Old 08-18-2010, 01:24 PM
CJ7-Tim
CJ7-Tim's Avatar
Yes.
CJ7-Tim is offline
post #9 of 11 Old 02-04-2013, 07:40 PM
Shizzmoo
Ok I had the hot starting problem. I got a new cps sensor and ignition coil but still the Same. It turns out it was a bad connection in the plug between the cps sensor and dissy cap on the left had side of the motor if Your looking at it from the from The front i cut plug out and soldered them together and no problems since. Starts every time
Shizzmoo is offline
post #10 of 11 Old 02-04-2013, 07:44 PM
CJ7-Tim
CJ7-Tim's Avatar
A damaged wire, or faulty wire plug has the same effect as a failed sensor, no signal to the ECU.
Wiring issues should always be considered and ruled out before you buy new parts.
CJ7-Tim is offline
post #11 of 11 Old 08-11-2014, 08:49 PM
abbottg
Junior Member
1987 YJ Wrangler
CJ-7 Tim, great post---thanks. This is the exact problem that has plagued a local Jeep Club member. I sent him your info. Hope it is the fix!
87 YJ, aka "money pit". 33x12.50r15 Treadwright muds, 4" rough country lift and shocks. AX15 and NP231, warrior fuel tank skid plate, Herculiner inner tub, family roll bar, VDP soundbar, Tuffy center console, white-out guages.
abbottg is offline
1998 Jeep Cherokee Limited cranks but wont start Dottie XJ Cherokee Technical Forum 5 02-25-2010 01:57 PM
1996 jeep cherokee WONT START mmitche6 XJ Cherokee Technical Forum 1 12-10-2009 05:33 AM
1991 jeep cherokee xj wont start savagex46jeep XJ Cherokee Technical Forum 0 10-17-2009 07:59 PM
1991 Cherokee No Start. Help! 1991cherokeeeee XJ Cherokee Technical Forum 7 01-30-2008 02:12 PM
My Jeep Grand Cherokee Wont Start. rudegual69 XJ Cherokee Technical Forum 2 12-29-2007 11:03 AM
