Quantcast 1991 130k Ignition issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1991 130k Ignition issue
Old 01-11-2005, 03:31 PM   #1
sowfpote
I've heard that cherokees are "hard starters". Is that true. Also, I smell gas on the inside. What is my course of action?
sowfpote is offline   Reply With Quote
Old 01-11-2005, 03:57 PM   #2
tripletsjeepin
Jeeps seem to turn over a couple times before they start... don't know why. The gas smell could be the result of your Injectors leaking. They can leak around the Orings or the housing itself can leak. I would check that out soon. I have seen Jeeps burn to the ground cause of it. good luck
1988 Cherokee, 4.0 liter, Auto
4.5 inch Rusty's lift, 33x 12.50 MTR's
Adjustable upper and lower control arms
GPS, CB, OBA, XM radio
Third row seating for the kids
tripletsjeepin is offline   Reply With Quote
Old 01-11-2005, 06:55 PM   #3
JoBo
As far as "hard starting" goes the older Renix ones take two revolutions of the crank to start and that seems like eternity but it's not. The Chrysler ones that I think started with the HO engine in 91 (?) start "normally". As for the gas fumes you had better find out before you end up a toasted marshmellow. Don't forget the fuel lines back by the fuel pump and filter. Also check the rubber hoses on the charcoal cannister under the hood near the firewall on the passanger side.
JoBo
JoBo is offline   Reply With Quote
Glock Forum
