1990 Xj Tranny Shifting Problems! - JeepForum.com
post #1 of 10 Old 11-10-2008, 04:04 PM Thread Starter
motorheadmach1
1990 XJ Cherokee
Im Sure This Will Be Just The Start Of Many Questions. I Have A 1990 Xj That I Just Got. Recently It Started Having A Proble In Teh Transmission. It Seems Like It Shifts Ricght From 1st Into 4th (od) If I Pull The Shifter Back Into 3 Instead Of Od It Shifts Down And Accelerates Fine. What Are The Possibilities Of This Being An Electronic Problem. Thankfully I Have A Spare Transmission In The 1991 Xj That I Just Rolled Over But I Dont Want To Install It If Its Even Compatable Being Thats Its Not A Renix System, And Have The Same Trouble, Thanks For The Help.
Andrew
1990 XJ, complete HO swap, approx 4" lift, 33 mt's, "trimmed" fenders, cobra CB, Homebrew roof light bar, 91' non disconnect front axle. various odds and ends.
"Friends don't let friends wrench alone"
motorheadmach1 is offline
post #2 of 10 Old 11-10-2008, 04:41 PM
keepishop
1989 XJ Cherokee
Right above your brake pedal there should be a yellow box with an AMC badge on it. It's the transmission control box, and somebody might have buggered it up. I don't have any exact values for you, but you might try tweaking some of the knobs and see if it makes a difference.
I bet you have your shift points turned all the way down.
keepishop is offline
post #3 of 10 Old 11-10-2008, 04:42 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
^^That box is for the cruise control.
The trans control unit is all the way on the passenger side under the dash, look to see if the fuse is blown, or you could try a replacement TCU from the junkyard. Also try adjusting your trans kickdown cable.
88XJSport is offline
post #4 of 10 Old 11-10-2008, 04:45 PM
keepishop
1989 XJ Cherokee
Really? I thought I saw something about the tranny written on it... and I don't have cruise.
post #5 of 10 Old 11-10-2008, 04:47 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Limited's have cruise.
post #6 of 10 Old 11-10-2008, 04:55 PM
keepishop
1989 XJ Cherokee
Well, you lean something new every day.
http://forums.off-road.com/general-4...okee-90-a.html
They actually use the same units as GM, on the turn signal
switch left to right
off ----->on------>accell
button
push and release = set cruise speed
hold down = coast
and of course when you hit the brake it turns off
post #7 of 10 Old 11-10-2008, 04:57 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
You will learn a lot here.
post #8 of 10 Old 11-10-2008, 08:11 PM Thread Starter
motorheadmach1
1990 XJ Cherokee
thanks for teh good info guys, how do i adjust the throttle pressure cable? (kickdown cable). and real quick will the body parts off the 1990 fit on the 1991 ie: fenders and back hatch?
post #9 of 10 Old 11-10-2008, 09:25 PM Thread Starter
motorheadmach1
1990 XJ Cherokee
btw 88 xj where that fuse your talking about?
post #10 of 10 Old 11-10-2008, 10:30 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
The fuse is in the wiring harness for the TCU. The TCU is mounted up there with nuts s the easy way to get it off it to remove the panel and the you can see the harness and then look for the fuse.
See page two
http://www.transonline.com/transdige...ers/index.html
Another tranny writeup
http://members.fortunecity.com/90limited/
I wonder to if the TPS sensor could be causing the problem half of it controls the throttle the other half controls parts of the tranny.
The kick down cable is attached to the throttle body linkage there is a "D" shaped button on top of the cable housing push it down then slide the plastic insert around the end of the cable back into the housing with the button still down open the throttle wide open and it will pulled the insert back out into proper position.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
Hard shifting + no shifting = auto tranny issue? DoubleBET XJ Cherokee Technical Forum 7 03-11-2011 08:06 AM
1990 Cherokee 4.0l tranny cooler fortyfreak9 XJ Cherokee Technical Forum 2 05-16-2009 06:25 AM
jeep cherokee 1990 shifting ? lilseth0014 XJ Cherokee Technical Forum 1 10-18-2006 03:02 PM
Tranny flush on 1990 XJ atfrith XJ Cherokee Technical Forum 7 08-31-2004 01:56 AM
tranny shifting problems darter340 XJ Cherokee Technical Forum 2 06-21-2004 05:44 PM
