1990 XJ Overheating Problem. - Page 2 - JeepForum.com
post #16 of 24 Old 10-24-2010, 08:39 AM Thread Starter
D0dgeRam1500
Originally Posted by EverydayXJ00 View Post
Is your auxiliary fan working? If your noticing more of an issue when your in stop and go situations and less on the hwy that could be the problem.
I'll have to check that next.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #17 of 24 Old 10-24-2010, 08:46 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by D0dgeRam1500 View Post
Could air be getting in due to a bad cap?
Not really, but if your crappy cap isn't holding pressure, it could cause overheating.........Wanna make a $9 gamble and try it since the one on there is probably gonna fail you in the future when you least need it to?
cruiser54 is offline
post #18 of 24 Old 10-24-2010, 11:00 AM Thread Starter
D0dgeRam1500
I'll order the cap tomorrow when I get home from school. Also my fan is belt driven but I have been looking into electric fans.
post #19 of 24 Old 10-24-2010, 11:03 AM Thread Starter
D0dgeRam1500
I have a new radiator and overflow, they are designed for the Cherokee but are aftermarket. Are you sure that cap will work with my setup?
post #20 of 24 Old 10-24-2010, 05:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If it's of the original design where the radiator has no filler neck or cap on it, and the recovery/pressure bottle is located near the passenger side firewall, then yes.
post #21 of 24 Old 10-24-2010, 07:19 PM
sargergp
If your radiator is in need of replacement anyway, go ahead and put them both on. This will probably fix your problem because it sounds like you're having the same problem I had on the '89 and '90 both. What I finally found was the problem on the '89 was the expansion and contraction of the overflow jug had warped the neck so that even a new cap wasn't sealing properly and once it warmed up it wouldn't hold pressure which caused it to overheat. So when I started having the same trouble with the '90 I immediately replaced the jug.
Also in another post you said your fan was belt driven. Does that fan sit in the center of the radiator or toward the passenger side. If it's not in the center your actually supposed to have an auxiliary electric fan beside it.
sargergp is offline
post #22 of 24 Old 10-24-2010, 08:45 PM Thread Starter
D0dgeRam1500
I ordered the new cap and it also appears that the fan next to the belt driven fan isn't kicking on. I hope its a sensor or something because the electrical is bad on the Jeep and I don't want to rewire it until spring.
post #23 of 24 Old 10-25-2010, 07:44 PM Thread Starter
D0dgeRam1500
And today I check the coolant level and find oil in the coolant...fml
post #24 of 24 Old 10-25-2010, 09:08 PM
travis2doorxj
i had the same problem and when throw three diff caps before finding one that would seal and never had a problem over heating after
travis2doorxj is offline
1990 , cherokee , jeep , overheating , xj
1990 Overheating Malachi73 XJ Cherokee Technical Forum 9 09-14-2010 10:48 PM
1990 Jeep Cherokee AW4 Problem ridebmxfbm XJ Cherokee Technical Forum 43 01-13-2009 01:21 PM
Charging problem on a 1990 xj wann495909 XJ Cherokee Technical Forum 11 03-28-2008 06:43 PM
Brake Booster Problem (1990) girlcrazy_4 XJ Cherokee Technical Forum 8 07-18-2006 09:22 AM
HELP with 1990 overheating!!! hockey10588 XJ Cherokee Technical Forum 2 09-16-2004 09:25 PM
