1990 XJ Overheating Problem. - JeepForum.com
post #1 of 24 Old 10-10-2010, 11:40 AM Thread Starter
D0dgeRam1500
I was driving my Jeep around town yesterday testing her out now that I have new tires on her and after about 25 minutes I noticed the engine temp gauge getting close to the red area. I headed home but when I got home the gauge was in the red and pinned. When I shut her off I heard the coolant overflowing. I don't know what else I need to check or replace but she has a new radiator, new hoses, new thermostat, new overflow, and she was flushed twice and she still overheats. Also before I replaced the parts her hood would get hot but now it doesn't anymore. Can anyone tell me what I overlooked?
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #2 of 24 Old 10-10-2010, 11:42 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
still the closed system?
1990JEEPXJ is offline
post #3 of 24 Old 10-10-2010, 11:46 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Did you "burp" it properly?
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #4 of 24 Old 10-10-2010, 11:50 AM Thread Starter
D0dgeRam1500
Yes, she is still running a closed system and I brought her to two different shops to flush her out because I don't have the machine to flush her correctly.
post #5 of 24 Old 10-10-2010, 11:53 AM
mecompco
mecompco's Avatar
1994 XJ Cherokee
Are you sure "they" got all the trapped air out of the system (aka "burping" it)? If not, that will cause overheating.
mecompco is offline
post #6 of 24 Old 10-10-2010, 12:41 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
to burp it jack up the rear of the jeep and remove the temp sender in the back of the head on the drivers side. remove the coolant pressure bottle cap and top it off. start the jeep and when coolant comes out of the back of the head, put the temp sender back in the head and close everything up. another way is to repeatedly squeeze the upper rad hose while the jeep is warming up. you should hear gurgling coming from the pressure bottle
post #7 of 24 Old 10-10-2010, 04:51 PM Thread Starter
D0dgeRam1500
I'm going to burp it on Tuesday after school. I'll tell you guys how it goes. Unfortunately I can't get to it tomorrow.
post #8 of 24 Old 10-10-2010, 04:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do yourself a favor while you're at it and replace the cap with a Stant 10244. It fits way better, holds a higher pressure, and doesn't contact the hood when the bottle expands. Most all other caps are crappo.
cruiser54 is offline
post #9 of 24 Old 10-11-2010, 12:32 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
my volvo cap still touches my hood when the bottle expends...
post #10 of 24 Old 10-11-2010, 04:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well it shouldn't. How much is that bottle expanding?
post #11 of 24 Old 10-11-2010, 08:48 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
not sure, but it does expand, obviously. just enough to kiss the hood. im sure its the bottle. its just a POS autozone replacement. but my jeep doesnt run hot with the exception of long climbs in 3rd.
post #12 of 24 Old 10-23-2010, 10:14 PM Thread Starter
D0dgeRam1500
I finally got around to burping it and it did have a lot of air in the system. It runs a lot longer before overheating but it still overheats. I can take it on the highway and the air cools it enough to get it back to 210. Is there anything else that could cause this?
post #13 of 24 Old 10-24-2010, 02:10 AM
EverydayXJ00
Is your auxiliary fan working? If your noticing more of an issue when your in stop and go situations and less on the hwy that could be the problem.
EverydayXJ00 is offline
post #14 of 24 Old 10-24-2010, 08:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Uh, a bad cap? Stant 10244. Al lthe other replacements, exept maybe from the dealer, are chinese junk.
post #15 of 24 Old 10-24-2010, 08:38 AM Thread Starter
D0dgeRam1500
Could air be getting in due to a bad cap?
1990 , cherokee , jeep , overheating , xj
1990 Overheating Malachi73 XJ Cherokee Technical Forum 9 09-14-2010 10:48 PM
1990 Jeep Cherokee AW4 Problem ridebmxfbm XJ Cherokee Technical Forum 43 01-13-2009 01:21 PM
Charging problem on a 1990 xj wann495909 XJ Cherokee Technical Forum 11 03-28-2008 06:43 PM
Brake Booster Problem (1990) girlcrazy_4 XJ Cherokee Technical Forum 8 07-18-2006 09:22 AM
HELP with 1990 overheating!!! hockey10588 XJ Cherokee Technical Forum 2 09-16-2004 09:25 PM
