1990 XJ ignition stuck - JeepForum.com
post #1 of 5 Old 05-03-2014, 02:10 AM Thread Starter
CPD32
Help!! Was having trouble turning the key in the ignition and getting it out sometimes. Yesterday I had the ignition lock cylinder changed and im still having the same problem! Its a 90 4.0 auto with tilt.
CPD32 is offline
post #2 of 5 Old 05-03-2014, 03:08 PM Thread Starter
CPD32
Anyone?!
CPD32 is offline
post #3 of 5 Old 05-03-2014, 03:26 PM
Motorcharge
Those old GM ignitions and columns just suck and wear out over time. Every XJ I've had with them didn't even need a key to start anymore. I could just grab the tabs on the ignition and turn it. I know it's not really the answer you want to hear and I can't help with your specific issue but it's something to be aware of.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #4 of 5 Old 06-28-2014, 08:58 AM
UrsaVictrix
I'm gathering from the forums it might be an issue of the jeep thinking it isn't in park and not releasing the key. Did you find a way to fix it.. I have the same problem.
UrsaVictrix is offline
post #5 of 5 Old 06-28-2014, 01:30 PM
UrsaVictrix
Mine turned out to be an old key... the other key works fine. I learned about some other possibilities if you still need a solution.. but it's been a month or so. Hopefully you figured it out already.
ignition
