1990 XJ 4.0 running rich - JeepForum.com
post #1 of 9 Old 02-10-2009, 08:33 AM Thread Starter
4hrs2Moab
1990 XJ Cherokee
I just bought this Jeep last night. The PO put new battery cables and battery in it, but they didn't put the cables in correctly. It barely ran when i picked it up but i drove it to a parking lot and discovered the ground strap from the valve cover to chassis was broken so I connected that and it idled smooth, lights were bright again, gauges worked, but it didn't solve the problem of running rich. I will rev it up and the damn thing smokes like a diesel but while driving, I cant see visible smoke out the window. My friend that was following me said it still stinks while on the freeway. What might be wrong? Oxygen sensor? CTS? TPS? BBQ?
4hrs2Moab is offline
post #2 of 9 Old 02-10-2009, 08:38 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
More than likely the O2 is out or on it's way out. How many miles on it?
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 9 Old 02-10-2009, 08:54 AM Thread Starter
4hrs2Moab
1990 XJ Cherokee
post #4 of 9 Old 02-10-2009, 08:57 AM
LobstahJeep
Pic for no click:
1981 CJ7
2001 XJ
ΜΟΛΩΝ ΛΑΒΕ
LobstahJeep is offline
post #5 of 9 Old 02-10-2009, 09:01 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Might not hurt to run a compression test on it so that you know where you're at (somewhat) mechanically. Only takes some of your time. Don't want to be chasing your tail here....
Did the previous owner have anything to say about this or oil consumption?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 9 Old 02-10-2009, 09:12 AM
LobstahJeep
Here is the original ad that Mat found the Jeep on:
http://www.ksl.com/index.php?sid=&ni...iew&ad=1091463
1981 CJ7
2001 XJ
ΜΟΛΩΝ ΛΑΒΕ
post #7 of 9 Old 02-10-2009, 09:16 AM Thread Starter
4hrs2Moab
1990 XJ Cherokee
post #8 of 9 Old 02-10-2009, 09:45 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
it could be a loose vacuum line somewhere. maybe the map sensor as well.
1990JEEPXJ is offline
post #9 of 9 Old 02-10-2009, 09:59 AM Thread Starter
4hrs2Moab
1990 XJ Cherokee
where is the map sensor? is it mounted up on the firewall? that was missing but i took it off the other jeep thats at my house and it still smoked
Fix running rich! JeepinXJstyle XJ Cherokee Technical Forum 6 11-19-2009 11:28 PM
Running Rich Meltedmechanic XJ Cherokee Technical Forum 21 05-10-2008 10:01 AM
1990 XJ Rich idle.. JoeOffRoad XJ Cherokee Technical Forum 0 02-15-2008 10:36 PM
running rich freedomhunter XJ Cherokee Technical Forum 3 12-30-2007 09:36 PM
Running Rich 4.0 ?? NOS/86 XJ Cherokee Technical Forum 3 09-29-2004 01:47 PM
