1990 xj - JeepForum.com
post #1 of 9 Old 10-13-2013, 09:51 AM Thread Starter
7ate90xj
1990 xj
Dont see alot of 1990 xjs, does anyone know how many were made?
my other question is what is the switch directly underneath the steering column? its just hanging there and looks like the other factory switches..It has it has a light on it.
7ate90xj is offline
post #2 of 9 Old 10-13-2013, 10:51 AM
Holder350
1995 XJ Cherokee
http://www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 9 Old 10-13-2013, 01:03 PM
miceanic
1990 XJ Cherokee
Picture of so called switch? Rear defroster/fog light/rear wiper/transmission power switch. These are the four factory switches my 1990 XJ came with. There are alot more 1990's out there than you think.
miceanic is offline
post #4 of 9 Old 10-13-2013, 03:45 PM Thread Starter
7ate90xj
transmission switch
Just found out from the guy i bought it from that when the switch is on the power to economy is activated. So how do i use the switch? city driving off? fwy on ? thanks!! the guys english isn't very good so i appreciate any input
7ate90xj is offline
post #5 of 9 Old 10-13-2013, 04:13 PM Thread Starter
7ate90xj
cooling system?
How do I burp the system its a 1990 XJ ? start it get it hot and kink the hose? thanks guys for any input!
7ate90xj is offline
post #6 of 9 Old 10-13-2013, 04:45 PM
miceanic
1990 XJ Cherokee
Why are you kinking the hose? The most recomended way is to find a small hill or lift the rear end high enough so the rear of the engine is above the front. Loosen the coolant temperature sensor on the back of the valve cover and wait for coolant to come out. This helps the air get out. it also helps to drill a tiny hole in your thermostat and place it at the 12 o'clock position to allow any air in the engine to ge out.
As far as the switch it just raises the shift points of the transmission. if you put it in economy it shifts like 200 RPM sooner to keep the engine speed down. Later models were permanently in power mode and the switch was eliminated. I keep mine in economy just because. Most will tell you to put it in power and leave it.
miceanic is offline
post #7 of 9 Old 10-14-2013, 06:01 PM Thread Starter
7ate90xj
Thanks for the fast response! I think my rear left rear drum need adjustment. What way do I spin the gear to tighten up or down ?
7ate90xj is offline
post #8 of 9 Old 10-14-2013, 06:04 PM Thread Starter
7ate90xj
[QUOTE="7ate90xj"]Thanks for the fast response! I think my rear left rear drum needs adjustment. What way do I spin the gear to tighten, up or down ? Thanks and sorry for the rookie question . This is my third xj..
7ate90xj is offline
post #9 of 9 Old 10-15-2013, 06:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Leave it in Power all the time.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
