Quantcast 1990 Wagoneer Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1990 Wagoneer Q's
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 02-08-2010, 05:57 PM   #1
sktr021
1990 XJ Cherokee
1990 Wagoneer Q's
Hey guys,
A relative has a 1990 Jeep Wagoneer with 150,xxx, 4WD runs good etc. He's asking 1400 but might come down a bit...not sure.
First of all, anything I should know about these things? Compared to a regular XJ.
Also, he says that he thinks the T-Case is gone out, but hes not positive. Said he was driving and started getting really bad driveline vibes so he took out the front driveshaft and that fixed the problem, and he hasnt messed with it since. He told me it was really hard to find a T-Case for these? Are there any other models that will swap into it relatively easily?(not sure what its got in there now)
Also, if im not mistaken, this has the older style cooling system, what is involved with the newer system swap?
Any other general information, websites or anything is appreciated too!
Thanks for any help you can give me.
sktr021 is offline   Reply With Quote
Old 02-08-2010, 06:15 PM   #2
nrpalmer32
nrpalmer32's Avatar
1987 XJ Cherokee
hello, I have an '87 XJ Wagoneer. The only difference is the front light setup, grill, fake wood grain, power everything and I htink most Wago's came wth the Dana 44 rear axle (the strongest rear axle for jeep). Mine has the AW4 tranny and NP242 xfer case, the xfer cases are not hard to find. THe front driveshaft is most like needing new u-joints, and they are like $15 dollars, not bad. I love my Wagoneer. I paid $400 for mine, so $1400 seems steep kinda. If you have any more questions feel free to pm me, or ask here.
nrpalmer32 is offline   Reply With Quote
Old 02-08-2010, 06:30 PM   #3
sktr021
1990 XJ Cherokee
Hey , thanks for the response man.
What kind of shape was yours in when you bought it? I havent seen it in a while but if i remember correctly its in very good shape. Hes an old man and never used the 4wd, and takes care of his vehicles like their his kids.
As far as motor and everything esle its all the same as the regular xjs then?
Im supposed to go take a look at it this weekend. Its very hard to find any information on these things!
That would be awesome if it had the D-44 in it!
Old 02-08-2010, 06:38 PM   #4
nrpalmer32
nrpalmer32's Avatar
1987 XJ Cherokee
Mine had a bad rear main seal, (about $30 if you do it yourself, including the RMS and oil pan gasket), and leaking timing chain cover. It had around 245k miles IIRC, but everything else worked great. Mine did come stock with the D44, and I removed my rear sway bar once I lifted it. Besides that the only thing that irks me is that the front side maker lights (next to the headlights) are NOT the same as XJ sidemarkers. Ours are a little skinnier and taller, even though every store says they're the same. But yeah, they are the same vehicles besides what I listed above. Some XJ have the NP242 and some have the NP231 xfer case, just look to see if you have full time 4wd, part time 4wd, 2wd and 4low on your xfer case shifter, if you do that is the NP242.
The only thing bad about the NP242 is that there are not as many aftermarket parts as the NP231 but I love the all wheel drive ability of it, so its worth the lesser amount of aftermarket support to me. post some pics of it once you get it!
Old 02-08-2010, 06:45 PM   #5
sktr021
1990 XJ Cherokee
Sweet deal! Everything is in working order except the issue with the vibes. Have you found anywhere that does have aftermarket support for these things?
I dont know much about 4wd so ill check it out next weekend when I(hopefully and probably) bring it home.
If you have more pics id love to see em!
Old 02-08-2010, 07:50 PM   #6
sktr021
1990 XJ Cherokee
Does anybody have any interior shots of these by any chance?
Old 02-09-2010, 12:05 AM   #7
nrpalmer32
nrpalmer32's Avatar
1987 XJ Cherokee
Its just the same as the other XJ's, no difference
Old 02-09-2010, 01:05 AM   #8
jeepdavetj
jeepdavetj's Avatar
1991 XJ Cherokee
I got access to a 99 that needs an engine for $1200. And it may not even need an engine. Just turns over and doesn't start. What I'm sayin is that for that money you can usually turn up cheaper XJ's. Look for a 91 or newer. Unless you really like the looks of a wagoneer. But all your really gettin is an odd ball grill and narrow flares. Maybe some odd wheels and gussied up interior. Just sayin if I wanted a Jeep with Wagoneer on it I would get a FSJ and enjoy the anemic 360
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline   Reply With Quote
Old 02-09-2010, 11:27 AM   #9
sktr021
1990 XJ Cherokee
I actually really like the looks of the wagoneer. And its a family vehicle so I know that Im not going to get burned with some sort of problem I dont notice at first. Also, I know that he has taken extremely good care of it, its garage kept and all. I know I could find something a bit newer for around 1200, but around here that price range comes with lots of problems.
I will have 1300 or so extra if i buy this, and would rather spend the money on cosmetic things to make it awesome( lift, tires, recovery etc.) than motor problems.
Its the sense of security...
Also Im in college and need the motor and tranny etc to be reliable, not something I may have to work on before I can even start driving it.
Old 02-09-2010, 11:33 AM   #10
sktr021
1990 XJ Cherokee
Thanks
Old 02-09-2010, 01:42 PM   #11
RedZeppelinXJ
buy the waggy....everyone and their brother has a cherokee (or 4)....but a waggy...thats rare and classy
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Laredo - The Grizzly Bomber (Trail Rig) 4.0/AW4/NP242/HP30/D35, 2"BB 31's
'91 XJ Briarwood - The Spruce Moose (Club Project) Can you say Chop-Top?
'79 J10 - Spartacus (Farm Project) 360/TH400/BW1305/D44's
RedZeppelinXJ is offline   Reply With Quote
Old 02-09-2010, 02:28 PM   #12
sktr021
1990 XJ Cherokee
I wish I had 4!!!
How rare are these things? cant find much info on them. hoping for a wagoneer "specialist" to chime in.
I know its just an xj trim package or whatever but still.
Old 02-09-2010, 03:51 PM   #13
danwho
danwho's Avatar
Jeep badged the Wagoneer in the early years, 84-90. In 91 they came out with the Briarwood, and the Waggy went away. This was the "top of the line" XJ at the time.
The Wagoneer Limited is a little different, it had "wood" paneled sides and leather seats, an upgrade.
I believe all Waggys had 4 headlights, although the early 4cyl diesel version may have had 2.
The only one's to consider, IMHO, are the years 87-90, unless you're going to replace the drivetrain.
It's probably an auto, which is good, because they all had the AW4.
These older ones that are rust free and in good shape are getting harder to find.
All in all, a good price for a 90. I would buy it myself in a heartbeat.
Good luck.
99XJ, looks pretty much like yours
93ZJ, Grand Wagoneer, bone stock
danwho is offline   Reply With Quote
Old 02-09-2010, 05:02 PM   #14
sktr021
1990 XJ Cherokee
Thanks Dan.
Seems like it was almost the predecessor to the Jeep Grand Cherokee's in a sense.
I will be checking it out saturday, and will take mucho photos.
Old 02-09-2010, 05:02 PM   #15
sktr021
1990 XJ Cherokee
Now to get that post count to 50 so I can show you guys whats up.
Glock Forum
