1990 Renix to HO Swap, Is it worth it? - JeepForum.com
post #1 of 6 Old 10-24-2010, 02:48 PM Thread Starter
jsc7002
1966 CJ5
I recently bought a 90 XJ with a 4.0L and it has several leaks and needs a lot of work, so I found a 93 HO motor and was wondering how hard it would be to swap in the HO or would it be best and easest to change the 93 HO to Renix?
Thanks for your help!
jsc7002 is offline
post #2 of 6 Old 10-24-2010, 03:26 PM
tbburg
Definitely easier to convert the '93 over to the renix system. You just swap all the sensors over while you do the engine change and run with it. Converting the '90 to HO wiring/computer/etc is a royal PITA It can be done, but why? You'll get most of the power increase by swapping the physical engine, and the renix system is pretty simple and robust.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #3 of 6 Old 10-24-2010, 05:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Make sure you use your Renix flywheel/flexplate and distributor. Also use an intake/exhaust gasket for the Renix. I say go for it. I've done it as have others here. Any questions, post up!!
cruiser54 is offline
post #4 of 6 Old 10-24-2010, 08:01 PM
5-90
5-90's Avatar
1988 XJ Cherokee
If you're going to swap engine mechanicals, you can swap just the head and intake (adapting the RENIX TPS to the HO throttle body) and get the same benefit.
If you're going to do a total transplant - electronics and all - I wouldn't bother unless you could get an OBD-II (1996-2001) donor. OBD-I isn't enough of an improvement to bother, I actually consider RENIX to be vastly superior (in terms of flexibility and reliability.)
Simplest overall - if you don't have a full vehicle as a donor - would be to swap the OBD-I top end on to the RENIX block, eliminate the EGR (which is ineffective on RENIX engines anyhow,) adapt the RENIX TPS to the OBD throttle body, and net significant performance improvements because the OBD-I head breathes better.
NB: Monitor your FAR after the swap - you may find you need slighly larger injectors to compensate for the increased airflow. IIRC, RENIX units are rated 19#/hr @ 39psig, you may need to get 20# or 21# units to feed the increased airflow (I want to recall that the RENIX injector duty cycle is relatively high already, and pushing a fuel injector to anything over 90%dc can result in premature failure of the unit.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 6 Old 03-17-2011, 09:17 PM
twmart
Cruiser have you swapped a 1996 engine into a 1990??? My daughter blew the engine in her 1990 and I just bought a complete running 1996 that has a trashed body. She drove it about an hour home and it runs GREAT...
So I am going to drive it myself a little and then do the swap. I do not plan on swaping the transfer case or trans I will keep the 1990 ones.
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
post #6 of 6 Old 03-17-2011, 09:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I did a 1992 HO to Renix. Pretty easy. Use the distributor, intake and exhaust making sure to use the Renix gasket, Renix flexplate and all sensors. Only difference MAY be the location of the water temp sender. Renix is at the back of the head. 96 may be at thermostat housing. If that's the case, use the HO thermostat housing and extend the wires, using the Renix sender..
will a 91 4.0 HO head swap onto a renix 89 using renix intake and exhaust hotrodded1970 XJ Cherokee Technical Forum 8 03-10-2013 08:04 PM
does renix include 1990, or only until '89? BigOrangeXJ XJ Cherokee Technical Forum 2 05-21-2008 02:27 PM
Throttle Position Adjustment on a 1990 Renix?? JoeOffRoad XJ Cherokee Technical Forum 0 02-02-2008 01:02 PM
1990 cherokee, 5 spd, 4x4 Worth 1000? alky350 XJ Cherokee Technical Forum 18 11-12-2005 05:13 PM
1990 Laredo for $1700 - worth it?? OkieRider XJ Cherokee Technical Forum 20 07-14-2005 10:18 PM
