1990 Jeep Cherokee Problem - JeepForum.com
post #1 of 11 Old 02-28-2012, 04:51 PM Thread Starter
Digger02
ok i have a 1990 jeep cherokee that i cant get to start. It has spark and pulse to the injectors. Theres pressure at the fuel rail. It acts like it will start but it doesnt. Also it fowls the plugs and puffs white smoke at im trying to start it. Any help would be appreciated im at the point of total frustration. Thanks in advance for the help.
Digger02 is offline
post #2 of 11 Old 02-28-2012, 05:13 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
1. Is the spark a snapping BLUE spark? Yellow/white/orange indicates a weak spark, which will not be strong enough to start the engine. Usual suspect here is the ignition coil. Your coil can be tested for both primary and secondary resistances with a meter and a manual.
2. If spark checks out (and only IF) introduce a small splash of fuel into the intake or a short shot of starting fluid. If it starts and runs for a short time, you have confirmed a fuel delivery problem. For a 1990, you need 31 psi to start and run the engine. Use a fuel pressure gauge if there is any question.
3. What is the status of tuneup hardware? Importance of this absolutely cannot be overstated. Fresh Champion copper plugs gapped to .035, new plug wires, distributor cap, rotor, fuel filter.
4. Still stuck.....run a compression test on all cylinders. You should have 120-150 psi, with no more than a 30 psi variation between cylinders.
5. Here is a link to an article that shows you how to test many things on the RENIX. Should be a bookmark for all RENIX owners.
http://www.lunghd.com/Tech_Articles/...iagnostics.htm
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 11 Old 02-29-2012, 06:18 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Aside from what Mr Walker says, check the plastic line that runs from your throttle body to the MAP sensor located on the firewall. No cracks, melted spots, poor rubber connections at either end.
cruiser54 is offline
post #4 of 11 Old 02-29-2012, 07:54 AM Thread Starter
Digger02
ok will try those tonight thanks again guys.
Digger02 is offline
post #5 of 11 Old 03-01-2012, 02:58 PM Thread Starter
Digger02
OK i tried ether and still wont start. Has a nice blue spark. Have to get a new compression tester the one i have is old. Im still baffled it feels like it has good compression. Could it be the ecm?
Digger02 is offline
post #6 of 11 Old 03-01-2012, 03:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
ECM is telling it to spark and ether should be ignited by that spark. Not the ECM.
post #7 of 11 Old 03-01-2012, 04:22 PM Thread Starter
Digger02
ok update got it start. Just unbolted the distributor and advanced the timing. Started. Then put it back in normal position. And it started again. But kicker is it runs real rough. and when it tries to start i can see the distributor wiggling. Kinda wierd. Any ideas on why it runs rough. maybe injectors?
Digger02 is offline
post #8 of 11 Old 03-01-2012, 05:01 PM
tjwalker
tjwalker's Avatar
Shouldn't have to do that to start the engine. With the "play" you mention, it might be time to find a salvage yard distributor to see if that resolves your issue.
tjwalker is offline
post #9 of 11 Old 03-01-2012, 05:41 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Take care of that distributor before proceeding any further.
post #10 of 11 Old 03-05-2012, 05:05 PM Thread Starter
Digger02
ok got the distributor issue fixed but now i have a new problem. when i put it in reverse or drive in 2wd mode i get nothing but when i shift into 4wd it will move forward and backward. but when i put it back into 2wd it will not move either way. also it grinds really loud for a second when i shift into park. any help is appreciated. thanks in advance.
Digger02 is offline
post #11 of 11 Old 03-06-2012, 02:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You're in neutral in the transfer case when 2wd is indicated. Adjust the linkage.
1990 Jeep Cherokee Problem Florentine XJ Cherokee Technical Forum 10 07-14-2009 07:33 PM
1990 Jeep Cherokee AW4 Problem ridebmxfbm XJ Cherokee Technical Forum 43 01-13-2009 01:21 PM
1990 Jeep Cherokee Tailight/Dash Lights fuse problem ridebmxfbm XJ Cherokee Technical Forum 1 09-27-2008 08:31 PM
1990 Jeep Cherokee Voltage/Stall Problem ridebmxfbm XJ Cherokee Technical Forum 5 04-01-2008 08:12 PM
1990 Jeep Cherokee power door lock problem bballplayer22 XJ Cherokee Technical Forum 0 07-20-2004 10:07 PM
