1990 jeep cherokee - JeepForum.com
post #1 of 8 Old 02-02-2010, 05:14 PM Thread Starter
2drlongarm
1990 XJ Cherokee
1990 jeep cherokee
I have a 1990 jeep Cherokee that i recently discovered had a gas leak at the number one and number three injector so i took both those o rings and replaced them it fixed the problem so i thought it sealed for about a day until the next morning i came out and now my inlet line to the fuel rail was leaking so i replaced the o rings in the line and it worked then i came out a day later to start it and realized that number 1 and 3 were leaking again so i decided that there was a bunch of carbon in the injector hole so i cleaned them all out and put the injectors back in it seemed to work until today i cam out and started it up and the leak is back at 1 and 3 again I'm not sure if it is a fuel pressure issue or not it just seems funny every time i fix it it seal up for about a day any help would be greatly appreciated
2drlongarm is offline
post #2 of 8 Old 02-02-2010, 05:33 PM
XJNUTTIER
Well it is kinda suspect, and I would almost think a build up in pressure would cause a condition like that, but I am not 100% sure,m Have you done a pressure test to the rail? Seems to make sense, the weakest link blowing, but to lose 2 o rings that your origionally replaced is what baffles me.. How are things in York? I am going to be there at my buddies house in the morning, to help him with his 01 XJ.. Do you know Andy Green, with the 8 inch long arm 01 XJ on 35's that got rolled in October?
XJNUTTIER is offline
post #3 of 8 Old 02-02-2010, 05:59 PM Thread Starter
2drlongarm
1990 XJ Cherokee
No i don't know Andy green I didn't pressure test the fuel rail but its a good idea i have no clue why it would be doing this other then it just had the fuel pump replaced I'm not sure if that would have something to do with it or not
post #4 of 8 Old 02-02-2010, 06:06 PM
XJNUTTIER
Yeah just curious man, he lives behind the prision in that area back there in the developments.. anyways, yeah that is something to really consider then, it may have too much pressure and is knockin out the weakest link, AKA being your 20 year old heat worn seals.. I would try to get your hands on a pressure tester, and test that fuel rail, and again it may even be the fuel pressure regualtor, and when you did your fuel pump, that may have not been the issue in the 1st palce, know what I am saying?
post #5 of 8 Old 02-02-2010, 08:30 PM
slimpartywagon
1989 XJ Cherokee
had same issue, different two injectors (3 and 6) ... found it to be bad injectors. replaced the injectors and no more issues since
slimpartywagon is offline
post #6 of 8 Old 02-02-2010, 08:41 PM
robdoggydog1
1970 CJ5
id take it apart and replace all 13 orings (1 for regulator on front of rail) with some quality rings from the dealer if possible. also... are all hold down bolts for the fuel secure? i.e only one bolt holding the rail in place or none all ?
robdoggydog1 is offline
post #7 of 8 Old 02-03-2010, 04:40 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That vintage of injector is notorious for leaking at a crimp/seam. You need new ones, all 6 of them. Quit messing around before you burn your Jeep to the ground.
cruiser54 is offline
post #8 of 8 Old 02-03-2010, 01:17 PM Thread Starter
2drlongarm
1990 XJ Cherokee
when i replaced the leaking o rings for the first time i inspected the others and there all good they haven't leaked yet it just seems like a pressure issue because none of the o rings didn't touch don't leak i thought maybe when i put the new ones in it would cause the old ones to leak but yet it keeps coming back to the same injectors with the new o rings it dosen't make sense to me its
1990 Jeep Cherokee Problem Florentine XJ Cherokee Technical Forum 10 07-14-2009 07:33 PM
1990 Jeep Cherokee 4lo Whistle ridebmxfbm XJ Cherokee Technical Forum 2 12-16-2008 08:39 PM
1990 Jeep Cherokee richd56 XJ Cherokee Technical Forum 6 12-06-2006 08:04 PM
1990 jeep cherokee? lilseth0014 XJ Cherokee Technical Forum 3 10-04-2006 04:26 AM
1990 jeep cherokee lilseth0014 XJ Cherokee Technical Forum 11 09-29-2006 02:05 PM
