Quantcast 1990 Clunk Clunk Clunk When Turning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1990 Clunk Clunk Clunk When Turning
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-15-2008, 06:31 PM   #1
ridebmxfbm
When I turn the jeep to the right it makes a weird loud clunking noise... as if your going up on a rollercoaster and it didn't stop until the wheel is straight, theres no noise when turning left only when turning right....
ridebmxfbm is offline   Reply With Quote
Old 03-15-2008, 07:13 PM   #2
RedJeepXJ
check your u-joints?
RedJeepXJ is offline   Reply With Quote
Old 03-15-2008, 07:17 PM   #3
1990JEEPXJ
1990 XJ Cherokee
can you feel it near your feet?
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 03-15-2008, 07:37 PM   #4
XJHERO
jack up the front end until the front tires are off the ground. grab the top of the tire and check for any play in the wheel bearing. if there is any play on either side you may have a bad wheel bearing.
98 XJ.
4.0 HO - AW4 - NP 231 - DANA 30, CHRYSLER 8.25
4.5" RE SUPER FLEX KIT, 32x11.50 BFG KM's
DIFF GUARDS, ENGINE AND TRANS SKID, CB
XJHERO is offline   Reply With Quote
Old 03-15-2008, 07:37 PM   #5
XJHERO
98 XJ.
Old 03-15-2008, 08:21 PM   #6
d768
1991 XJ Cherokee
transfer case will make sounds/vibrations regardless of turning. i do get the clunks myself when turning, sometimes.
1993 3dr XJ i6 4x4 , in the works but road-going :p
MY THREADS
[url]http://www.jeepforum.com/forum/showthread.php?t=520942[/url]
[url]http://www.jeepforum.com/forum/showthread.php?t=515576&page=2[/url]
[url]http://www.jeepforum.com/forum/showthread.php?p=4827827#post4827827[/url]
[url]http://www.jeepforum.com/forum/showthread.php?t=521632[/url]
d768 is offline   Reply With Quote
Old 03-15-2008, 08:42 PM   #7
1990JEEPXJ
1990 XJ Cherokee
its very vague, does it increase with speed? where do you feel the clunk? im thinking it could be the exhaust hitting the cross member. never said anything about a t-case. i figure to check the simple easily repairable things first.
Twin 242's
The 'build' thread
Old 03-15-2008, 10:20 PM   #8
ridebmxfbm
Alright I don't know where it is but it's the same at every speed but it starts at about 10-15mph and all the way up only when turning right though and I thought it would be the tire rubbing somewhere but it's not so I'm unsure of what it is...
Old 03-16-2008, 07:36 AM   #9
turbojeep88
any excess play in the steering? track bar maybe?
turbojeep88 is offline   Reply With Quote
Old 03-16-2008, 10:12 AM   #10
conrasm
Could be tie rod ends in steering, ball joints, control arm bushings or track bar mounts.
Mine was a worn hole (ovaled out) in the lower track bar mount on the axle. That can be fixed by welding a piece of steel over the front of the bracket with the correct sized hole drilled in it. That bolt is a 10mm.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Old 03-16-2008, 11:54 AM   #11
ridebmxfbm
there is no play at all anywhere with the steering... I was thinking it was the tie rods but I'm unsure it only clunks though no hop or anything just clunking..
Old 03-16-2008, 11:57 AM   #12
conrasm
Have someone turn the wheel with the truck on the ground and watch the track bar. It is subtle, but it can move if there's something worn on it.
Shawn
Old 03-16-2008, 12:44 PM   #13
ridebmxfbm
alright thanks alot and what exactly is the track bar? This is my first jeep im used to a car, I bought the jeep as my daily driver.. thanks
Old 03-16-2008, 03:04 PM   #14
CharlieMopps
1989 XJ Cherokee
Sounds like a bad hub/bearing to me. When my hub went bad it would make that noise, and it would get worse when I turned left, but would go away when I turned right... because it was adding/removing pressure from the failing bearing. The new stock hub cost me $130 and was easy to install once I had a gear puller ($20 at Harbor Freight)
CharlieMopps is offline   Reply With Quote
Old 03-16-2008, 03:44 PM   #15
ridebmxfbm
how can I check for sure its the stock hub I dont want to buy it being it cost so much and that not be the problem thanks...
Glock Forum
