1990 Cherokee Laredo 4.0L won't start - JeepForum.com
post #1 of 5 Old 09-26-2006, 11:02 PM Thread Starter
thjofe
I have been experiencing this problem for several weeks now.
It will run fine for days and then all of a sudden NOTHING.
I have checked several things for the cause of the problem i.e.; Fuel Pump, Fuel Pump Relay, Fuel Filter, etc...
I was reading that it might be the Cranckshaft Position Sensor?? I was told that it was located on the driver's side of the bellhousing and it was a PITA to get off but for some reason I cannot locate this mystery part?? there is nothing on the drivers side of the bellhousing on my JEEP and now my JEEP is not starting at all. It usally starts after awhile but today it just cranks and cranks
anything anyone can suggest would be GREAT!!!
thjofe is offline
post #2 of 5 Old 09-27-2006, 07:09 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Look into the engine compartment and floow the bell housing up and down till you find a wiring harness (couple of wires in a loom) coming out of it. The sensor is pretty well recessed into the housing.
Find it and find the connector for it. Disconnect it and reconnect it a couple of times to clear the contacts. The try it again.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 09-27-2006, 10:57 PM
severous01
severous01's Avatar
also look into a factory alarm. my chip fried and was making a semi-connection...sometimes. i had to remove the alarm and then i had no problems...and still dont over 5k miles later...happy as can be.
oh, an easy way to test this is to short the starter relay (with it in neutral or park) and see if it still starts...or beat the starter a few times with a deadblow or rubber mallet to see if it's the starter.
severous01 is offline
post #4 of 5 Old 09-28-2006, 12:07 AM
xjawgi
that thing on the bellhousing is a crank position sensor, and yes it could be the cause of your no start problem.
xjawgi is offline
post #5 of 5 Old 09-28-2006, 12:30 AM
Jeepin_XJ_101
11 O'Clock position of the bellhousing if your looking from the tranny, 1 O'Clock if your looking from the engine bay. The connector is right behind the throttle body. It is held on the bellhousing by 2 bolts spaced like 2 inches apart with the sensor inbetween. Hope that was descriptive enough.
"When in doubt... Floor it"
1989 XJ 4.0L I6 -
- NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline
94 Grand Cherokee Laredo won't start. iguana5000 XJ Cherokee Technical Forum 2 12-18-2009 04:33 PM
1990 Jeep Cherokee will crank but not start ridebmxfbm XJ Cherokee Technical Forum 9 09-20-2009 11:31 AM
1990 cherokee hard start- need PN and ? vintage_car XJ Cherokee Technical Forum 0 11-19-2008 10:13 AM
92 Cherokee Laredo 4.0 won't start issue. pseverin XJ Cherokee Technical Forum 1 04-24-2007 07:50 PM
Would newer '00 flares fit my 1990 cherokee laredo twisted_ed XJ Cherokee Technical Forum 2 11-08-2004 05:31 AM
