1990 cherokee 4.0L starting problem - JeepForum.com
post #1 of 6 Old 08-14-2009, 09:20 AM Thread Starter
vintage_car
a few things have happened and no idea if any of this is related.
2 days ago, hard starting, that afternoon, it cranked but wouldn't fire. I sprayed some starter fluid in the throttle body and it fired up. Yesterday morning, it cranked but wouldn't fire. Starter fluid didn't help. Yesterday afternoon it did 2 things, cranked but would start, and then just a click no turning over. Waited a couple minutes and it would crank but not turn over.
I checked spark, there isn't any at the plug or the distributor.
Would a low battery allow for turning over but no spark? Not sure what to look at first.
vintage_car is offline
post #2 of 6 Old 08-14-2009, 11:15 AM
GeologistFelix
1990 XJ Cherokee
My guess is that it's a bad coil or a bad crank position sensor. The starter fails as a result of low voltage before the coil/distributor, I believe. The clicking was probably your starter solenoid, though, which means the starter wasn't getting enough juice, so a low battery could be contributing to all of this.
GeologistFelix is offline
post #3 of 6 Old 08-14-2009, 11:56 AM Thread Starter
vintage_car
replacing coil or CPS
how difficult is it to replace the coil and CPS?
post #4 of 6 Old 08-14-2009, 03:12 PM
GeologistFelix
1990 XJ Cherokee
Well, the CPS is a gigantic pain (note: I say that never having done it myself; just reading about it here on the forums), but the coil is pretty easy; you just have to move the wires and hoses out of your way and unbolt it, then put in the new one.
Probably good to disconnect the battery first, but that's all there really is to it, since it's right under the hood, not under anything large or difficult to move.
post #5 of 6 Old 08-14-2009, 08:07 PM Thread Starter
vintage_car
cps did it
It was the crank position sensor. You are right it is a pita! 7/16th socket worked on the bottom bolt, I had to bend a 7/16 wrench to get to the top one, along with jamming my arm between the firewall and rear of the engine. Fired up after I was done.
post #6 of 6 Old 08-15-2009, 01:37 PM Thread Starter
vintage_car
midfiring now
jeep ran great for about 20 miles and now it is shuttering with any sort of accelleration or even at idle. I'm assuming this shuttering feeling is misfiring. Would the CPS go bad that quick? I got this part from Auto Zone, has a 2 yr warranty. Can the CPS move at all and cause this problem?
1990 Jeep Cherokee Problem Florentine XJ Cherokee Technical Forum 10 07-14-2009 07:33 PM
1990 Jeep Cherokee AW4 Problem ridebmxfbm XJ Cherokee Technical Forum 43 01-13-2009 01:21 PM
1990 Jeep Cherokee Voltage/Stall Problem ridebmxfbm XJ Cherokee Technical Forum 5 04-01-2008 08:12 PM
Starting Circuit Electrical Fault in 1990 Cherokee emhunde XJ Cherokee Technical Forum 2 05-20-2007 05:34 PM
1990 cherokee not starting madsky1 XJ Cherokee Technical Forum 14 02-13-2007 07:01 PM
