1990 4.0 xj injector question - JeepForum.com
post #1 of 10 Old 07-21-2013, 11:05 PM Thread Starter
Elrod90xj
1990 XJ Cherokee
I don't know if I'm posting in the right place and this is my first post sorry if I'm doing this wrong. Lol. I have a 1990 xj automatic 4.0, I want to replace my fuel injectors and I hear that ones from a neon are better than the stock xj's I was just wondering if anybody here knows what years from the neon will fit my xj. Thanks!!!
Elrod90xj is offline
post #2 of 10 Old 07-22-2013, 12:08 AM
Holder350
1995 XJ Cherokee
On a renix replacing injectors won't help much with power until you do some upgrades on how much air the engine can get
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 10 Old 07-22-2013, 06:08 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't do it for power. Do it because the stock ones leak externally. You will get better idle and a bit better throttle response though.
Hopefully someone will chime in with teh proper application for you. Refurbed later model injectors are available on ebay also.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 10 Old 07-22-2013, 01:05 PM Thread Starter
Elrod90xj
1990 XJ Cherokee
Thanks guys, Although more power would be nice, that's not why I am wanting to do the swap. I just figure that better injectors would give me a better running jeep and like cruiser 54 said, I definitely wouldn't want leaking fuel injectors. And I plan on doing a cai and hood vents sometime in the future when I get the funds
post #5 of 10 Old 07-22-2013, 01:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Excellent plan.
That said, how many of my Renix tips have you done so far?
post #6 of 10 Old 07-22-2013, 08:56 PM
79chiefs
1988 XJ Cherokee
http://thexjguys.wordpress.com/2012/...injector-swap/
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #7 of 10 Old 07-22-2013, 11:05 PM Thread Starter
Elrod90xj
1990 XJ Cherokee
It looks like I have a lot of cleaning to do cruiser, I haven't even thought of all that but now my weekend will be full. I my front blinkers quit working awhile back and I've changed bulbs, fuses, those circular blinker and hazard relays on the fuse box, and still won't work. I noticed there is some white grease or gunk where the bulb sits, maybe I can clean that out too? And thanks 79chiefs, I will use your write up.
post #8 of 10 Old 07-23-2013, 05:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This is in Post # 3.
I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals making sure they havenít retracted into the plastic holder, and then plugging it back together. Thereís a critical 10-pin connector for the front lighting system located in front of the air cleaner and behind the left headlight assembly. Donít miss that one. Also be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight.
ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then plug them back in. I do this on every Renix Jeep I purchase or work on for someone else.
Revised 07/23/2012
post #9 of 10 Old 07-26-2013, 12:07 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
I checked that 10 pin connector and man it is dirty. I tried to clean it up a bit, but it looks like I could use a new one. All of my lights work except the front blinkers. My right turn arrow wont turn on, sometimes if I turn the left on then quickly switch it to right it will start blinking. I'm thinking it might be the switch in the steering column. Man I hate electrical problems.
post #10 of 10 Old 07-26-2013, 06:19 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Small wire brush and pipe cleaners with some BrakeKleen. You'll have it looking like new in no time. I'd also tweak the connectors so they grab the pins more tightly. Don't be skeered.
