1989 Jeep Cherokee Laredo - JeepForum.com
post #1 of 3 Old 09-24-2011, 02:22 PM Thread Starter
rubenroblesj
I have an 1989 Jeep Cherokee Laredo that I had parked for about three years. I started it occasionally at first but this last year I hadn't started it at all. So far I am not getting any fuel at the fuel rail. I had replaced the fuel pump about eight months before I parked it. I replaced the fuel pump ballast resistor since those tend to go out quite often. When I try starting the Jeep, it cranks and cranks but won't start. The Ballast resistor gets smoking hot, and once the ballast resistor wire on the Starter Relay side burnt. I replace the wire and decided to check the jeep for any electrical shorts. So far I have noticed that under the jeep at the fuel pump electrical connector (pigtail)when disconnected and tested with a test light, the connectors have juice, but once connected and tested at the wires going into the fuel pump there is no juice. Any advice????? Please...
Is it possible for the Fuel Pump to have a short and be causing the power to return to its original source causing some kind of short???
rubenroblesj is offline
post #2 of 3 Old 03-20-2012, 07:42 AM
jlmoore143
Could be something with the ignition. Maybe bad. Try replacing the cam position sensor.
jlmoore143 is offline
post #3 of 3 Old 03-20-2012, 03:04 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
89 has no cam position sensor.
OP: Inspect the relays on the passenger inner fender and the associated wiring. Any chance some rodents got in there and chewed stuff up?
cruiser54 is offline
Jeep grand cherokee body strenghthening rebelsonjeep JeepForum Announcements 2 05-23-2011 06:24 PM
Ft Wayne Indiana Jeep Jam At O'Daniel with a JEEP STYLE Poker Run Jeepsruskaup JeepForum Announcements 0 10-05-2009 09:27 AM
Mods for Jeep grand Cherokee MimiJGCmb2000 JeepForum Announcements 1 06-08-2004 09:19 PM
