1989 Cruise Control - JeepForum.com
post #1 of 8 Old 02-22-2010, 09:44 AM Thread Starter
My1989Jeep
1989 XJ Cherokee
1989 Cruise Control
Hello, My Jeep came with factory cruise control but it doesn't seem to work. What makes the cruise control work? What wires do I check?
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline
post #2 of 8 Old 02-22-2010, 01:36 PM
el_pedro
1990 XJ Cherokee
a common problem is the wires in the steering column going bad,
the wire to check comes out of the little stalk for your signals and goes into the steering column area. on my dad's xj it looked like a phone extension cable sorta
el_pedro is offline
post #3 of 8 Old 03-08-2010, 01:39 AM
RussoGuitar
1989 XJ Cherokee
any other input on this?i ive got the same problems and wanted some ideas as to where to start? is there a fuse for the cruise control?
RussoGuitar is offline
post #4 of 8 Old 03-08-2010, 07:36 AM
tangofox007
There is a switch on the brake pedal. The wire sometimes gets broken by big feet.
tangofox007 is offline
post #5 of 8 Old 03-08-2010, 08:17 AM
Saudade
1988 XJ Cherokee
Do your HVAC vents work ok in all positions or do they default to defrost only?
Saudade is offline
post #6 of 8 Old 03-08-2010, 09:49 AM
RussoGuitar
1989 XJ Cherokee
All positions so its not a vacuum issue, i believe its electrical.
post #7 of 8 Old 03-08-2010, 10:11 AM
Wiskey
1991 XJ Cherokee
There is a really awesome PDF about this here:
1993 Jeep Cherokee Cruise Control System Troubleshooting | car service & repair guide
Go down to the bottom of the article, and click on the word "Here" to get it. This PDF tells you all about the cruse system, how to test all the components. It's how I fixed mine
Whiskey
Originally Posted by Rescue XJ View Post
Seafoam. . . Its the closest thing to an enema for your engine.
Wiskey is offline
post #8 of 8 Old 03-08-2010, 10:11 AM
Wiskey
1991 XJ Cherokee
Whiskey
Wiskey is offline
Cruise Control Will Not Set xjguy98 XJ Cherokee Technical Forum 2 11-18-2008 03:27 PM
1989 cruise control question philr XJ Cherokee Technical Forum 8 12-26-2006 04:45 PM
cruise control / speed control jasondh XJ Cherokee Technical Forum 7 06-08-2004 09:11 PM
cruise control / speed control jasondh XJ Cherokee Technical Forum 1 06-08-2004 08:59 AM
Need help with Cruise Control jupiter57 XJ Cherokee Technical Forum 2 08-17-2003 06:26 PM
