1989 cherokee laredo sputters - JeepForum.com
post #1 of 1 Old 11-29-2008, 10:21 AM Thread Starter
coachkemm
1989 FSJ Cherokee
I have a 1989 cherokee laredo 4.0 engine. It started sputtering whenever I pressed the gas. I thought it was the plugs. But I checked the oil and it was a little frothy and white. I thought the head gasket went but it wasnt overheating or shooting white smoke out of the tailpipe. I dont want to start dumping money into it if it is the head gasket. Can someone help? I recently got an oil change at walmart and put an engine flush in. Is it possible they didnt drain all the flush out and it did something to the engine? Also the sputtering is worse when the heat is on. Please help
coachkemm is offline
1989 jeep laredo 300,000 miles should I buy? Jeeper4life XJ Cherokee Technical Forum 12 02-09-2011 04:33 PM
1989 Jeep Cherokee Laredo Build 89SAFARIXJ XJ Cherokee Technical Forum 155 02-06-2010 02:37 PM
1989 4.0 Idles Low and Sputters jlcljayne XJ Cherokee Technical Forum 2 07-07-2008 06:52 AM
1989 Laredo major fule issue plexathor XJ Cherokee Technical Forum 2 02-06-2008 01:21 PM
Timing for 1989 Jeep Cherokee Laredo se7vn XJ Cherokee Technical Forum 2 10-11-2007 02:06 PM
