1989 cherokee ccv part number? - JeepForum.com
post #1 of 8 Old 11-08-2013, 12:20 PM Thread Starter
joedarr33
1989 XJ Cherokee
I have a 1989 cherokee with the 4.0
I am looking for the part numbers of the grommet and elbow on the back of the valve cover (the pcv/ccv whatever you want to call it) I need the grommet and the elbow. I have looked every where and cannot seem to find it for my year and what not.
Thanks
I got the jeep used, and it has the grommet with nothing comming out of it in the back, which i believe is causing the blow by problem im having. So i am looking for the parts to go in.
The front vent tube that goes into the intake is there and is in good shape.
joedarr33 is offline
post #2 of 8 Old 11-08-2013, 03:09 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Renix Vacuum Harnesses
The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367
The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK-715-1366.
The tube from the rear of the valve cover to the intake manifold is part number 715-1365.
Revised 09-11-2012
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 8 Old 11-08-2013, 05:43 PM Thread Starter
joedarr33
1989 XJ Cherokee
i got the tube but i could not find the other two above. I searched at napaonline.com
Thanks alot for the help btw!
post #4 of 8 Old 11-08-2013, 05:47 PM Thread Starter
joedarr33
1989 XJ Cherokee
Actually ill just go to napa tomorrow and check it out.
will these two parts work?
http://shop.advanceautoparts.com/web...searchTerm=pcv
post #5 of 8 Old 11-08-2013, 05:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Possibly. I know Dorman supplies the same stuff. As to whether that's it, I don't know.
post #6 of 8 Old 11-08-2013, 10:06 PM Thread Starter
joedarr33
1989 XJ Cherokee
does it look like the same? i have been trying to figure this **** out for a bit and my blow by is getting crazy because of this solid grommet being there. I know im being a pain but i cant find these parts ANYWHERE and the guy threw all of the other stuff away im guessing when he decided to put a solid grommet on there.
also i looked for the part numbers you posted and they didnt come up
post #7 of 8 Old 11-09-2013, 05:11 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just go to Napa.
post #8 of 8 Old 11-09-2013, 06:54 PM Thread Starter
joedarr33
1989 XJ Cherokee
http://shop.advanceautoparts.com/web...ntent=10711125
Just in case someone else needs this itsdoorman part number 46005 from auto zone, its what i needed. Its the ccv in the rear closest to the fire wall. It came with the grommet,tube,and fitting for it (everything need to replace the entire rear ccv set up) For only $10 dollars. Im very happy with it so far. Should fix my blow by problem.
