1989 Cherokee 4.0 Barely runs - JeepForum.com
post #1 of 7 Old 03-24-2013, 10:10 PM Thread Starter
Trooka
1989 XJ Cherokee
Ok, so I have searched the forums for days now. I have found similar problems but not exact as mine. my problem is my Jeep is barely running, it pops, backfires, spits, sputters, backfires through intake, well yeah thats about it. I purchased it 4 days ago, so far I have tried 2 different ignition control modules, cleaned intake, cleaned throttle pos sensor, cleaned IAC, replaced spark plugs, all have had absolutely no positive changes in the idle, or rev. I know the timing is non adjustable, but I didnt know that before and attempted to twist the distributor to adjust the timing. call me crazy but it did change it. it made is so the thing would idle but still any throttle at all it would fall flat on its face, and pop backfire and sputter. since then if I start it again it will not idle correctly again. tomorrow I am going to check fuel pressure, I also checked the resistance of the Crank Position Sensor it was within operating range. also the previous owner said it happened 1 month after the local mechanic shop replaced the clutch. when you try to start it now I believe they screwed something up in the clutch because it will make some nasty metal on metal noises out of the tranny/flywheel/starter. any help would be much appreciated!
Trooka is offline
post #2 of 7 Old 03-24-2013, 11:50 PM
bigbadduck
1987 XJ Cherokee
Sounds like your fuel pressure is too, check pressure at rail you should have 39 psi at idle. If pressure is low check fuel filter and pump.
bigbadduck is offline
post #3 of 7 Old 03-25-2013, 07:16 AM
sbaird95
x2... also check the strainer in the fuel pump, sounds like the problems i had when my strainer was clogged.
sbaird95 is offline
post #4 of 7 Old 03-25-2013, 08:28 AM
ComancheKid45
1988 MJ Comanche
Check your map sensor and the vaccum line associated with it.
96 XJ Country
ComancheKid45 is offline
post #5 of 7 Old 03-25-2013, 07:25 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Actually the fuel pressure spec for an 89 is 31 psi at idle. Then disconnect the vacuum line leading to the fuel pressure regulator and the pressure should then jump to approximately 39 psi.
Be sure that the vacuum line is pulling good vacuum line and is not wet with fuel. If it is wet with fuel, you have a ruptured fuel pressure regulator.
If all that checks out, I agree with testing your MAP sensor.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 7 Old 04-04-2013, 08:49 PM Thread Starter
Trooka
1989 XJ Cherokee
diagnosed...
so you guys are probly gonna poop chickens on this one. after EVERTHING checked out I decided to drop the tranny and possibly part it out. whomever replaced the clutch forgot to tighten and/or threadlock the flywheel bolts. at low RPM's the flywheen was off balance giving the crank pos sensor enough of a reading to run but not much else. so tighten and lock the bolts, put back together and tadah... 400$ jeep fixed. thanks a bunch for your help everyone. and im sure I will be needing your help again. hopefully not but lets be real.... its a jeep after all....
Trooka is offline
post #7 of 7 Old 04-24-2013, 11:30 PM
Simmbad
1976 CJ7
nice glad you fixed it
Simmbad is offline
cherokee , fuel pressure , idle issue , jeep , not running
