1988 XJ wont go in 4wd - JeepForum.com
post #1 of 6 Old 07-14-2013, 07:52 PM Thread Starter
gpalmer456
1988 XJ Cherokee
did some trading and got my hands on a ratty xj that I've been wrenching on for a couple of months now. I got the brakes fixed, one of the oil leaks, and diff cover leak fixed. Now I am trying to figure out why it wont go in 4wd. The lever will go into 4H (wont go into anything else) but wont engage and there is a grind noise almost like some gears aren't fully meshed. Got underneath and I am completely confused. Can anyone direct me to a diagram, explain to me how the linkage is suppose to work, or give me any tips on how to diagnose the problem?
gpalmer456 is offline
post #2 of 6 Old 07-14-2013, 08:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I let off the gas, throw the lever, and then tap the gas and let off.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 6 Old 07-14-2013, 08:16 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
And:
Transfer Case Linkage Adjustment
Straight from the FSM:
SHIFT LINKAGE ADJUSTMENT
(1) Shift transfer case into 4L position. (make sure your shifter is fully in the 4L position)
(2) Raise vehicle.
(3) Loosen lock bolt on adjusting trunnion (Fig.
87).
(4) Be sure linkage rod slides freely in trunnion.
Clean rod and apply spray lube if necessary.
(5) Verify that transfer case range lever is fully
engaged in 4L position. (you can do this under the vehicle at the transfer case)
(6) Tighten adjusting trunnion lock bolt.
(7) Lower vehicle
post #4 of 6 Old 07-14-2013, 08:22 PM Thread Starter
gpalmer456
1988 XJ Cherokee
lever wont move beyond 4h no matter what is done.
post #5 of 6 Old 07-14-2013, 08:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Poke your noggin under the Jeep and have a gander. Here's why:
Chipmaker says:
“Way more problems get solved by using your five senses under your hood rather than your ten fingers on a keyboard”
post #6 of 6 Old 07-15-2013, 01:58 AM
Timo_90xj
Timo_90xj's Avatar
Linkage adjustment.
If that won't cure it, you've got an internal problem on the TC. It is not unheard of that a 231 or 242 has broken shift forks or worn shift fork slide pads.
***Under construction***
Timo_90xj is offline
