1988 cuts off randomly - JeepForum.com
 2Likes
  • 1 Post By S8NNG8
  • 1 Post By S8NNG8
post #1 of 3 Old 03-09-2016, 03:16 PM Thread Starter
Jeep88lxj
1988 XJ Cherokee
Xj 1988 cuts off randomly
I have a 1988 Jeep Cherokee XJ Laredo and I have been struggling with this cutting off issue a lot lately. Whenever I start it it cranks right up, but after I drive it or even move it a little bit, it starts to sputter and it completely shuts off on me. It starts right back up afterwords though. I'm not sure if it's not receiving gas or if it is an electrical issue. So far, I have replaced the ignition coil, the ignition coil module, the battery, the CPS, TPS, and the idle sensor. I can't seem to narrow it down! Please help me out! Thanks!
-Isaac
Jeep88lxj is offline
post #2 of 3 Old 03-09-2016, 11:47 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Check your ground to the motor. If the cable is barely long enough it may be getting pulled on when you start to move. The amount of movement would depend on the condition of your drive train bushings(motor mount, trans mount).
Jeep88lxj likes this.
D3<!L!>3D
S8NNG8 is offline
post #3 of 3 Old 03-11-2016, 07:21 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I have had the same exact problem with my '98 ZJ. I just figured it out yesterday. Mine turned out to be a bad connection at the fuel pump. After all my fears of what I may be in for, it cost me a wire connector. I was able to narrow it down cuz of the movement being an essential detail. Taking off from a dead stop and hitting the speed bumps in my trailer court were the usual scenarios that triggered it.
D3<!L!>3D
S8NNG8 is offline
