1987 Cherokee Overflow tank - JeepForum.com
post #1 of 17 Old 04-25-2007, 10:14 PM Thread Starter
Skaf
I have to replace my plastic overflow tank and cap atleast 2 times a year to maintain the correct pressure in my cooling system. The plastic starts to expand and the cap starts to leak etc... I have been looking around to see if anyone has made custom tanks that have maybe thicker plastic or a tank made of metal. Somthing to last me longer then 6 months. This is for a 1987 jeep cherokee. Just wondering if anyone else had the same problems and if anyone has any ideas.
Thanx
Skaf is offline
post #2 of 17 Old 04-25-2007, 10:44 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
i have the same problem. im on the third or fourth tank. im just really tempted to convert to the open cooling system of 91+ and ditch the bottle all together.
1990JEEPXJ is offline
post #3 of 17 Old 04-26-2007, 12:52 AM
88_xj_hunter
1988 XJ Cherokee
I converted my '88 to an open system. On the other two, I had a local racing radiator shop make me a couple of overflow tanks out of aluminum and I'm using a 16 lb cap. Paid like $60 each, but at least no more worries. The shop that did it for me said he's done probably a hundred for Cherokee owners. He has a template already made up and could mass produce them I guess.
'89 XJ Laredo 4.0L, AW4, NP242, Dana 30, 35 w/Lock Right, 5.5" lift, 35x12.50x15 Uniroyal m/t
'88 XJ 4.0L, AW4, NP231, Dana 30, 35 w/Lock Right, 4.5" lift, 31x9.50 SuperSwamper on salvaged 15x7's
'87 XJ Pioneer 4.0L, AW4, NP231, Dana 30, 35 w/ trac-loc, currently stock, 8" lift one piece at a time
Originally Posted by mdonohu1
i sweat your nuts. badly.
88_xj_hunter is offline
post #4 of 17 Old 04-26-2007, 08:44 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Thats funny, im only on my 2nd bottle (recent one put on in 97) and mine still works without problem. But i did see somebody that was selling a metal tank for the closed cooling system, and it is solving all of their problems that you are describing. If i find it ill post back.
88XJSport is offline
post #5 of 17 Old 04-26-2007, 12:38 PM Thread Starter
Skaf
Hey 88_xj_hunter you wouldnt happen to know the phone number to the race shop that made that overlfow tank for you would you?
Skaf is offline
post #6 of 17 Old 04-26-2007, 12:43 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
LEAD_NOT_FOLLOW is offline
post #7 of 17 Old 04-26-2007, 09:43 PM
88_xj_hunter
1988 XJ Cherokee
sent you a PM on that tank. I'll take some pics of it tommorow and post them.
post #8 of 17 Old 10-06-2011, 12:44 PM
Waldo4
1988 XJ Cherokee
I found a site that has a metal overflow tank for an 88, but it is $288... Thats a bit over priced I know. I was thinking of having a custom motorcycle place make one. Since it is very much like a motocycle gas tank anyway. But if anyone has a site that has the metal tanks, I would love to get the url for it or an e-mail. Thanks.
Gardez la Foi
Waldo4 is offline
post #9 of 17 Old 10-06-2011, 01:00 PM
FleshEater
2014 JK Wrangler
Convert it to an open system...especially if you have cooling components that are old anyways and could use being replaced. It's ultimately a radiator, heater valve and hoses with some wiring for the e-fan and you're done.
I've got my system priced out at $320 for pretty much brand new everything (excluding coolant cost).
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #10 of 17 Old 10-06-2011, 04:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
A simple trick to solve this problem easily is to replace the cap with one specified for a Volvo. It grips the threads on the tank better than those cheapy chinese caps ever thoght of doing, even if the tank is a cheapy chinese one. Napa has them for about $10. It's a 703-1396.
cruiser54 is offline
post #11 of 17 Old 10-06-2011, 04:16 PM
mountainjock
1988 XJ Cherokee
my hood was hitting the top of the reservoir and eventually causing a leak. When I installed my second one, I lowered the mounting bracket. Don't know if your situation is the same.
mountainjock is offline
post #12 of 17 Old 10-06-2011, 04:18 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Funny you should mention that. The Volvo cap is also a lower profile and is much less likely to contact the hood when the bottle expands.
post #13 of 17 Old 05-09-2013, 09:02 AM
lawrencecomanch
Does anyone have a part number for that volvo cap? Or at least know what model volvo cap will fit the jeep? No one in town carries replacement bottles or caps for jeeps but I think I may be able to find one for a volvo if I know which cap I'm looking for.
lawrencecomanch is offline
post #14 of 17 Old 05-09-2013, 03:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Duuuude. Read Post # 10!!!
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
post #15 of 17 Old 05-10-2013, 01:10 PM
lawrencecomanch
whoops! good eye. Thanks you
Coolant pouring out of my overflow tank jwiowa XJ Cherokee Technical Forum 7 12-19-2009 10:27 AM
Overflow tank boiling over. MSH5337 XJ Cherokee Technical Forum 12 01-08-2009 05:28 PM
1987 XJ gas tank volume craigincali XJ Cherokee Technical Forum 6 10-31-2007 08:13 PM
help with 89 overflow tank leak eas020223 XJ Cherokee Technical Forum 4 04-27-2005 11:16 AM
how to fix leaking overflow tank? eas020223 XJ Cherokee Technical Forum 4 02-06-2005 01:36 PM
