-   -   1987 Cherokee Overflow tank (http://www.jeepforum.com/forum/f11/1987-cherokee-overflow-tank-407056/)
Skaf 04-25-2007 10:14 PM
I have to replace my plastic overflow tank and cap atleast 2 times a year to maintain the correct pressure in my cooling system. The plastic starts to expand and the cap starts to leak etc... I have been looking around to see if anyone has made custom tanks that have maybe thicker plastic or a tank made of metal. Somthing to last me longer then 6 months. This is for a 1987 jeep cherokee. Just wondering if anyone else had the same problems and if anyone has any ideas.
Thanx
1990JEEPXJ 04-25-2007 10:44 PM
i have the same problem. im on the third or fourth tank. im just really tempted to convert to the open cooling system of 91+ and ditch the bottle all together.
88_xj_hunter 04-26-2007 12:52 AM
I converted my '88 to an open system. On the other two, I had a local racing radiator shop make me a couple of overflow tanks out of aluminum and I'm using a 16 lb cap. Paid like $60 each, but at least no more worries. The shop that did it for me said he's done probably a hundred for Cherokee owners. He has a template already made up and could mass produce them I guess.
88XJSport 04-26-2007 08:44 AM
Thats funny, im only on my 2nd bottle (recent one put on in 97) and mine still works without problem. But i did see somebody that was selling a metal tank for the closed cooling system, and it is solving all of their problems that you are describing. If i find it ill post back.
Skaf 04-26-2007 12:38 PM
Hey 88_xj_hunter you wouldnt happen to know the phone number to the race shop that made that overlfow tank for you would you?
LEAD_NOT_FOLLOW 04-26-2007 12:43 PM
Convert it to an open loop setup.
http://www.jeepforum.com/forum/f11/ultimate-cooling-system-questions-391636/
88_xj_hunter 04-26-2007 09:43 PM
sent you a PM on that tank. I'll take some pics of it tommorow and post them.
Waldo4 10-06-2011 12:44 PM
I found a site that has a metal overflow tank for an 88, but it is $288... Thats a bit over priced I know. I was thinking of having a custom motorcycle place make one. Since it is very much like a motocycle gas tank anyway. But if anyone has a site that has the metal tanks, I would love to get the url for it or an e-mail. Thanks.
FleshEater 10-06-2011 01:00 PM
Convert it to an open system...especially if you have cooling components that are old anyways and could use being replaced. It's ultimately a radiator, heater valve and hoses with some wiring for the e-fan and you're done.
I've got my system priced out at $320 for pretty much brand new everything (excluding coolant cost).
cruiser54 10-06-2011 04:07 PM
A simple trick to solve this problem easily is to replace the cap with one specified for a Volvo. It grips the threads on the tank better than those cheapy chinese caps ever thoght of doing, even if the tank is a cheapy chinese one. Napa has them for about $10. It's a 703-1396.
mountainjock 10-06-2011 04:16 PM
my hood was hitting the top of the reservoir and eventually causing a leak. When I installed my second one, I lowered the mounting bracket. Don't know if your situation is the same.
cruiser54 10-06-2011 04:18 PM
Funny you should mention that. The Volvo cap is also a lower profile and is much less likely to contact the hood when the bottle expands.
lawrencecomanch 05-09-2013 09:02 AM
Does anyone have a part number for that volvo cap? Or at least know what model volvo cap will fit the jeep? No one in town carries replacement bottles or caps for jeeps but I think I may be able to find one for a volvo if I know which cap I'm looking for.
cruiser54 05-09-2013 03:26 PM
Duuuude. Read Post # 10!!!
lawrencecomanch 05-10-2013 01:10 PM
whoops! good eye. Thanks you
The time now is 10:54 AM.
