1987 4.0 Renix wiring help - JeepForum.com
post #1 of 2 Old 08-20-2017, 06:41 PM Thread Starter
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
I'm working on undoing all the PO's work. I have a few thinking in need to wrap up. Any help would be appreciated
Starting on the drivers side...
1.throttle body. Is the top hole is open. Should it be plugged in to anything or filled
2.back of the block near injectors 5 & 6
3. Back of the block near injector 6
4. Plug by the air box. Pretty sure this is for the e-fan... because its missing
Passengers side
5. Plug with TCM grounds
6.
7. Purple plug coming out of the back of the heater box grommet
8. Red wire coming out of the harness by the battery
April 2014 & 2015 COTM
MOBBiN is offline
post #2 of 2 Old 08-21-2017, 06:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
1: http://cruiser54.com/?p=280
2ash water temp gauge connector. You have the wrong sender in your head.
3:See 2^^.
4:Yes
5:I can't see what you're taling about.
6:4WD light switch connector?
7:Goes to the heater control valve which you might not have. Plug it.
8:Not stock looking.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
