1986 jeep cherokee xj help - JeepForum.com
post #1 of 4 Old 02-13-2013, 06:16 PM Thread Starter
1986cherokeenc
1986 XJ Cherokee
Hello, will a 2.8L v6 from a camaro/s10 fit in my jeep? it came stock with a 2.8L v6 and im trying to replace it.
1986cherokeenc is offline
post #2 of 4 Old 02-13-2013, 08:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pretty sure it will. But, I would research doing the GM 3.4 swap if it were me.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 4 Old 02-22-2013, 01:39 PM Thread Starter
1986cherokeenc
1986 XJ Cherokee
Its not just a bolt off bolt on? would i have to change bell housings? or what?
post #4 of 4 Old 02-22-2013, 01:47 PM
Hudson
The 2.8L can be replaced by a GM 60-degree 3.4L engine from the Camaro. The 2.8L and the 3.4L have the same exterior dimensions, making it an ideal swap. The primary difference between the two is on the inside - stroke and bore size.
Just realized I didn't even answer your question.
Yes that engine will bolt in. The GM built 60 degree V-6 is the same engine also used in the Chevy S-10s and other vehicles.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
cherokee , engine , xj
