1982 Jeep Cherokee - JeepForum.com
post #1 of 7 Old 08-13-2002, 09:42 AM Thread Starter
ChargerMD
1982 Jeep Cherokee
I just bought a 1982 Jeep Cherokee Chief. Its a 2 door, 4 wheel drive, 4speed (they might all be- I'm not very familiar with these models). It has 114k miles, a perfect body with no rust and no a/c, seems to run good. I paid $2375.00, included in the deal was all the a/c components and a spare 360 cu engine. Did I get hurt here? I have no idea what these things are worth. Is there anyway to tell how many of these things were made?
I need to get some floor insulation and carpet (it was taken out and its very hot inside with out it)- does anyone know where I can find some quality carpet?
I was told that this model had only underdash mounted a/c (also thats what it looks like in the owners manual). I supposedly have all the necessary parts for the installation- has anyone ever done this? if so how difficult is it?
I'm sorry for so many questions from a newbie. Thanks for any information anyone might have.
2001 Jeep Cherokee Sport
1982 Jeep Cherokee Cheif
ChargerMD is offline
post #2 of 7 Old 08-13-2002, 10:37 AM
arpy
If it runs I'd say you did good, I've always wanted one of those, they look TOUGH!
Check with JCWhitney on the carpet, they don't list it online but I bet they have it. They do show that year Wagoneer online, same body but 4 door only I think. Give them a call or get a print catalog. www.jcwhitney.com
You might want to get some expert help with the a/c if you are not familiar with this. Try to find a tech that will do it "on the side" so you don't have to pay shop labor rates, just don't get them in trouble with their job.
arpy is offline
post #3 of 7 Old 08-13-2002, 01:34 PM
EricsXJ
The Post man
EricsXJ's Avatar
Since the carpet has already been taken out, and there's no rust, why not herculine the interior floors?
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 7 Old 08-13-2002, 06:14 PM
Tomguy
2014 WK
That black Herculiner would only make it hotter
I saw roll car carpeting at Pep Boys for $25 a roll, but I didnt look at it for color or how much is in a roll. Looked about 8' long.
Hemi, Towing & Lux
198k
Previous: 1972 Benz 280SE 4.5, 1992 XJ Cherokee Laredo, 2006 Charger R/T
Tomguy is offline
post #5 of 7 Old 08-14-2002, 05:33 AM Thread Starter
ChargerMD
I thought about a spray in liner but around here it very expensive. And I also worry about the heat as Tomguy mentioned. I've never had much luck with rolled auto carpet seems to wear out easily.
I only found one place that could get me formed carpet (Ohio Auto Mat) and they would have to make it ($270.00). Has anyone ever dealt with this company? If so, what kind of quality did you receive?
post #6 of 7 Old 08-14-2002, 09:23 AM
glenzx
glenzx's Avatar
From what I remember from my 84 full-size wagoneer about REMOVING the A/C is that indeed, the duct inside just screwed up underneath the dash, the fan/evaporator was a pain in the *** to get to and remove and the hoses went through a weird grommet on the passenger side firewall. The compressor should be a "York" which if in good condition is awesome! The hoses as they came through the firewall went up and onto the pass. side wheelwell (there should be a little glass viewport in the supply line, I believe, and that was sort of at the high point of the well...) Then one tube went to the compressor, the other to the condensor in front of the radiator, then a hose from there back to the compressor.
BTW, the AMC 360 is a bomber engine! The original owner that I bought it from had put 117,000 miles on it, pretty hard ones at that, and before I sold it I put another 100,000 miles on it. No oil burning and ran strong. A lot of the emissions stuff was a real pain in the *** to maintain, so if you can get away without that crap, more power to you! The most major work I did was to pull the heads and have them re-built. That engine was so smooth and powerful, I wish I could stick one into my 2K Cherokee! Whooooeeee! That truck with the 3-speed Torqueflight Auto. Trans. hauled major ***! Fully loaded down going up hills, it just didn't matter. I got abou 14-15 mpg overall....
glenzx is offline
post #7 of 7 Old 08-14-2002, 12:38 PM Thread Starter
ChargerMD
Thanks for the good info. I'm denifinately not looking forward to installing the a/c- probably need to get a service manual if I can find one. The gas milage was 13.2mpg - but thats alright my 2001 only gets 18 mpg (I tend to drive hard). I have quite a vibration above 55 mph- I'm trying to narrow it down. So far I've turned the front rotors and repacked the front wheel bearings- no help.
The tires have hardly any miles on them- but they're cheapo belted tires. Also its hard to get into 2nd gear (downshifting) unless I bring the shifter all the way to the right then back to 2nd !!!???.
Help! Clueless Female with Jeep Cherokee! Jeep won't start after lots of repairs! TRA1216 XJ Cherokee Technical Forum 33 10-28-2012 02:28 PM
tv in jeep cherokee trosejeep XJ/MJ Cherokee Non-Technical Forum 12 08-06-2009 09:54 PM
1982 Cherokee wipers only work at high speed. fasteddieofgalt XJ Cherokee Technical Forum 2 10-14-2008 10:39 PM
Will 1999 Jeep Cherokee SE seats fit my 91 Cherokee? Igofaster13 XJ Cherokee Technical Forum 11 01-16-2007 08:09 PM
My 98 Jeep Cherokee... 98XJ-ID XJ Cherokee Technical Forum 9 05-26-2004 06:07 PM
