15inch rims on a 2001 jeep Cherokee?? - JeepForum.com
post #1 of 17 Old 04-11-2012, 05:14 PM Thread Starter
Happypwnstar
Will 15 inch wheels fit on a 2001 jeep cherokee? the dude at big o said its risking it but i think he was talking about a grand cherokee, which i am not its an XJ not a GRAND cherokee. He said on the 01's the calipers were bigger and it would hit.
Is this true I cant find any info on a 01 XJ just earlier models and WJs.
(again this is an 2001 XJ regular cherokee not a WJ aka grand cherokee)
Happypwnstar is offline
post #2 of 17 Old 04-11-2012, 05:27 PM
AZ Jeff
2014 JK Wrangler
Since the older ones came stock with 15's, I see no reason why a later one would have any issues in stock configuration.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 17 Old 04-11-2012, 05:28 PM
BriansCJ
1994 XJ Cherokee
The dude at big o is retarded.
XJs used the same calipers pretty much their entire life span. They were also used on YJs, ZJ, MJs, and TJs.
15" wheels will fit no problem. I think some 01 XJs even came with 15s.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 17 Old 04-11-2012, 05:42 PM
jeepjunkymike
what he said
lift it,,,,fat girls cant jump
jeepjunkymike is offline
post #5 of 17 Old 04-11-2012, 05:44 PM
cbenez1
What they said..... Big O guy =
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #6 of 17 Old 04-11-2012, 05:47 PM
critmuncy99
Never heard of calipers being to big,But 99 and up used bigger rotors if im not mistaken.Maybe someone else might chime in.....
(J-E-E-P) Chew Them Up And Spit Them Out The Other End (J-E-E-P)
critmuncy99 is offline
post #7 of 17 Old 04-11-2012, 05:53 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Not bigger rotors, just cast rotors. They are the same diameter, just a bit deeper.
xjfever is offline
post #8 of 17 Old 04-11-2012, 05:58 PM
ChiliPepperXJ
2006 WK
And you have confirmed on why I avoid Big O like the Bubonic plague
ChiliPepperXJ is offline
post #9 of 17 Old 04-11-2012, 09:32 PM
BriansCJ
1994 XJ Cherokee
The rotor/hub change in 99/00 was just a change in depth. The height/depth/width of the hub changed, whichever way you are looking at it. So the rotors offset changed to space it differently so it would line up with the SAME calipers. Sort of like changing baackspacing on wheels. You can use newer stuff on older Jeeps and vica versa. You just have to make sure the hubs match the rotors.
- Slow
BriansCJ is offline
post #10 of 17 Old 04-14-2012, 05:18 PM Thread Starter
Happypwnstar
Just ordered some 15x8 wheels thanks for your replies everyone.
post #11 of 17 Old 04-14-2012, 06:45 PM
krabby124
The steelies on mine which are stock are 15's and that's all I see on jeeps are 15's. Unless they are the newer wranglers that have the moabs and what not from the factory.
XJ Build Thread
YJ Build Thread http://www.jeepforum.com/forum/f22/95-high-school-yj-build-1411192/
krabby124 is offline
post #12 of 17 Old 04-14-2012, 09:10 PM
cpttuna
I have a 99,00 and 01 XJ. All three have 15 inch rims. The rotors changed in 99. some 99's had cast rotors,some had composite.
cpttuna is offline
post #13 of 17 Old 05-07-2015, 09:18 PM
Consteth
15s will fit.
Consteth is offline
post #14 of 17 Old 05-08-2015, 02:34 PM
bluejunior
bluejunior's Avatar
Most did, including both of mine. 16's were an upgrade option.
Lifted, Locked, Stiffened
bluejunior is offline
post #15 of 17 Old 07-16-2015, 11:25 PM
Danielrebuffoni
So I can run 15s on a wj 2001
Danielrebuffoni is offline
rims , tires , wheels
2001 Jeep Cherokee RHD annienet XJ/MJ Cherokee Non-Technical Forum 5 02-15-2012 02:14 PM
2001 Jeep Cherokee Shoup XJ Cherokee Technical Forum 5 05-04-2008 05:49 PM
2001 jeep Cherokee timmur XJ Cherokee Technical Forum 1 10-17-2007 12:35 PM
2001 jeep Cherokee timmur XJ Cherokee Technical Forum 16 10-05-2007 11:03 PM
HELP with 2001 Jeep Cherokee 4x4 anthonysmith XJ Cherokee Technical Forum 7 05-13-2006 11:18 AM
