150-200 miles per tank - JeepForum.com
post #1 of 56 Old 02-28-2011, 06:17 PM Thread Starter
ZexGX
1987 XJ Cherokee
Is 150-200 miles per tank in 2WD mode highway cruising @ 2k RPM normal out of a Renix '87 4.0L I6/automatic 4WD 4DR Cherokee w/factory 3.55 axles and 31" tires? If not, any suggestions? I've already replaced:
Distributor, ICM, coil, plug wires, plugs, fuel pump, fuel filter, 1 fuel injector, and ran a can of SeaFoam in the gas tank a while ago.
My 300+HP V8 Firebird gets more miles to a tank on Premium...
'87 XJ 4 door 4.0L 4x4 420k+ miles - not enough mods
'99 Firebird V6+4L60E w/BAR certified LS1+4L60E swap - as many mods as the Jeep
ZexGX is offline
post #2 of 56 Old 02-28-2011, 06:24 PM
Crunch
I'm with ya.. My 2000 with a 3+" lift, 31's and 4.10's is getting the same..150-200 per tank...
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering
Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift.
SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it!
Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff.
Crunch is offline
post #3 of 56 Old 02-28-2011, 06:24 PM
Kitchen
oh wow, you dont drag race at every stop light do you? but all jokes aside check your hose to make sure they are all connected, i was get the same(about 180 a tank) until i realized one of my hoses going to my intake was disconnected, plug it back in and got 270ish on each tank. my plugs were leaned out. your o2 sensor might be bad as well.
- 99 XJ
5 inchs on 33 kevlars
Locked F&R, bumper, winch, etc...
Build thread:
- 03 TJ Rubi
4 inches on 35 baja MTZs
Stock rubi stuff(D44s, lockers, skids, etc...)
Kitchen is offline
post #4 of 56 Old 02-28-2011, 06:25 PM Thread Starter
ZexGX
1987 XJ Cherokee
That's gotta be it! No real vaccum leaks since idle is between 600 and 1000, warm. I am also going to be replacing a suspicious injector electrical connector too since the copper wire is a little exposed.
P.S. I have drag raced it. It ran an 11.2 consistent. In the 1/8th mile. 4WD launch, since 2WD just one-wheel-peeled the Procomp A/T's. 2.4 60'. I think I was the only one laughing.
ZexGX is offline
post #5 of 56 Old 02-28-2011, 06:35 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Unless you have corrected your speedometer you are actually traveling farther than what it is showing with 31" tires. I get 14.5 mpg's with 32" tires and 3:55 gears.
xjfever is offline
post #6 of 56 Old 02-28-2011, 06:44 PM Thread Starter
ZexGX
1987 XJ Cherokee
You're right - my speedometer is 3-6MPH off depending on speed, thus the odometer would be off... That's comforting. I still have to refill at least twice a week (damn small gas tank).
ZexGX is offline
post #7 of 56 Old 02-28-2011, 06:54 PM
BeepBeepGoJeep
1994 XJ Cherokee
i usually get 185 or so a tank with 31s and 307s...sucks.
[]IIIII[]
BeepBeepGoJeep is offline
post #8 of 56 Old 02-28-2011, 07:07 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
when was the last tune up?
i can get about 270-290 with 33's and stock gears. and thats accounting for the speedo difference.
1990JEEPXJ is offline
post #9 of 56 Old 02-28-2011, 07:48 PM
wlc78
1997 XJ Cherokee
my XJ has a 3" lift and 31 AT's and i get between 270 and 290 miles per tank depending on how gas happy i am.
wlc78 is offline
post #10 of 56 Old 02-28-2011, 08:45 PM
lk123
1993 XJ Cherokee
i get the same lol i cant wait to see how horrible my mileage is when i put on my 33's...i need to get my regear/axles done lol
4.0 I6ho Sport RC LA 6.5"
95 Lexus Sc300 coiled on 19's
94 ZJ 5.2 v8 Limited 3" rancho*sold*
93 2wd pos xj sport *sold*
89 nissan 240sx *wrecked*-03 Cbr954rr *traded*
2nd 89 nissan 240sx *sold*
lk123 is offline
post #11 of 56 Old 02-28-2011, 08:48 PM
BeepBeepGoJeep
1994 XJ Cherokee
thats the only reason i went with 31s, im not even gonna bother with bigger tires till i swap in new axles with different gears.
[]IIIII[]
post #12 of 56 Old 02-28-2011, 09:07 PM
lk123
1993 XJ Cherokee
my jeep looks retarded on 30's with 6.5lift lol after the 33s are done with and im pretty sure my axles and gears will be on the jeep ill end up being on 35's
lk123 is offline
post #13 of 56 Old 02-28-2011, 09:14 PM
Crunch
I haven't corrected mine.. I'm actually racking up more miles then I'm going.... Means I'm getting even less...
Crunch is offline
post #14 of 56 Old 02-28-2011, 09:36 PM
XJlumberjack
1997 XJ Cherokee
I'm getting around 150-200 miles per tank as well (~12 MPG) in my '97 XJ 4WD I6 this winter. This does involve a good amount of city driving and short trips but I don't step into it all too often, so I feel like I should be getting more. Any suggestions? (I've replaced the spark plugs and wires, run fuel injector cleaner and new air filter). It does have 186k miles on it, so is there anything that anyone would recommend replacing to work towards better mileage (on a low budget)?
XJlumberjack is offline
post #15 of 56 Old 02-28-2011, 09:51 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
no it means youre getting more. more actual miles driven will equate to more MPG than when using odometer mileage
How many miles to a tank do you get? lollygagger8 XJ Cherokee Technical Forum 76 11-19-2010 10:46 AM
Miles/Range per tank.... xjfan XJ Cherokee Technical Forum 17 01-18-2008 01:01 PM
160 miles to a tank? Jeep Cherokee XJ Cherokee Technical Forum 46 12-13-2007 11:35 PM
Just got 194 miles on my last full tank EJames1226 XJ Cherokee Technical Forum 48 12-21-2005 04:00 PM
Miles per tank Slammed_Am XJ Cherokee Technical Forum 15 06-13-2004 03:37 PM
