#1 | |
11 mpg to 18 mpg!
After getting my XJ road-ready, I was horrified to find that my first full tank of fuel resulted in 11mpg, even after new plugs, wires, cap, rotor, and air filter. This was mostly rural commuting with few stops and low speeds, with a bit of light, in-town, grocery-getter use as well.
No codes stored, and I checked the CTS, MAT, and MAP sensors with a multimeter, which were all within range according to Haynes. Here are the changes I made, which combined to improve the mileage to 18 in the same mixed commuting/town conditions: 1. Removed existing exhaust/cat and replaced with 2.5" muffler/pipe (used, but in good shape, from my parts waggy) 2. Removed existing downpipe and hammered almost all of the "dent" out at the top of the pipe (couldn't use waggy's nice, newish, 2.5", undented downpipe, as it is a renix and is a different shape) 3. Seafoam through the tank, highly concentrated (1 can with 25 litres of fuel) and drove it hard until that was burned) 4. New O2 sensor 5. Left trans in "comfort" mode instead of "power" mode. Draw your own conclusions as to which is most responsible for the increase. I think it is primarily the 02 sensor. "Comfort" mode seems to not only shift at slightly different points, but seems to lock up the torque converter earlier, which helps. Without the cat (I know, I know, I am going straight to hell for this) and with the exhaust moving more freely, there is a definate "seat of pants" improvement in power. As always, YMMV. ![]()
Recovering moparholic |
#2 |
So does the seafoam smoke at all once you pour it in ur gas tank? And about the cat, I would LOVE to do that too but I have to go through DEQ pretty soon. And from my experience with the "Power" and "Comfort" settings, I know the comfort shifts at lower rpms which I would think give better gas mileage but I think I get a little better in Power mode? maybe I'm just crazy but it seems like it. Thats a HUGE increase in MPG tho, good job!
#3 |
No smoke from seafoam when run diluted through the tank - I think it mostly cleans the injectors used this way, but might remove some of the carbon and deposits as well (?).
#4 |
Thats an amazing mpg increase i have to say, I would also like to remove the cat and put in a strait pipe but I have to wait till 2011 when my Jeep becomes exempt from the drive clean program up here in Ontario Canada.
1991 XJ Cherokee 2 Dr 4WD Presently Stock |
#5 |
Spare your transmission's life and keep it in power mode. I also got better MPG in power mode as well.
1988 Jeep Comanche- SporTruck | 4.0L Renix |AW-4 | 4x2 Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors Suspension: Gabriel VST Shocks Tires: Firestone "Firehawk Indy 500" 235/70/15's |
#6 | |
I'd rather have an 18 mpg Jeep with no converter, than a 11 mpg Jeep that was politically correct. You've done well, grasshopper. |
#7 | |
There are probably half a million Supras and Cressidas and 4runners out there still running around with AW4s whose grey-haired owners never switched to power mode! ![]()
#8 |
replace fuel filter as well.
put 35 psi air in tires. remove roof rack. 18 mpg is pretty good. 20-24 mpg for me right now. keep the cat.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd 3" Lift + 31" Tires / D35 TracLok / NP231 Drilled out Stock Airbox / Gauge Cluster Upgrade Magnaflow Muffler / High-flo Cat / MSD Coil |
#9 |
id say most of it is from the o2s being changed out. they make a dramatic change!
#10 |
It smokes if you undo the PCV line and pour it in while the motor is running, but somebody has to be on the gas to keep the car from stalling out......and it will give a nice smoke show for your neighbors.
#11 |
Geez I guess I need to update my stuff. 13mpg is killin me.
1988 YJ 32x11.50 (Sold) 1987 XJ 3.5 RE super-ride kit. 31x10.5 (Totaled, someone ran a stopsign) 1995 XJ 3.5 RE super-flex kit. 31x10.5 (Brother Flipped) 2001 XJ CRAPPY ABS (Sold) 1998 XJ RC 6.5. 31x10.5. (Sold) (Current)1996 XJ 4.5 RE super-flex kit. 33x10.5 (Locked and loaded) All were DD |
#12 | |
And geewally I agree, me too. However, If I'm on flat ground though at 70-75mph, I can watch my ECO meter on the trip comp vary between 20-26mph consistently. Now, around town, going up and down this hilly state, yep.... 10-13mpg buddy. Of course, it doesn't help that I still haven't done my gears and I'm running 33's on 3.55's. ![]() Edit: now that I've been commuting about 35-40 miles a day for work, I've been seeing an average of about 17-17.4mpg. Not tooooo bad but more is always better.
Colorado Jeep Club Member #76
#13 |
Man I have to breathe the air the same air that you are dumping all that **** in without your cat. Put it back on!
1998 Chili Pepper Red XJ. Flowmaster 50 series Delta Flow. Lift in the future. |
#14 |
lol here we go agian. No worries though, with how the air flows around the world, by that time his air reaches you, his little cat will be the least of your breathing problems.
#15 |
I'd be more worried about the thousands of planes in the sky that burn fuel at an unbelievable rate. A 767 that burns one complete 'tank' of fuel probably puts out more **** than a Jeep without a cat will in its lifetime.
