108F-120F What temp is ur Xj at - JeepForum.com
post #1 of 25 Old 06-16-2013, 02:23 AM Thread Starter
hshark
So I've read a lot and I mean a lot of threads about XJ running temps etc. Some people say oh my XJ runs at 195 and 210. Some people say oh my XJ runs at 210 year round etc. So I've come to ponder that these temps might seem logical in say cooler areas of our nation, but what about in the not so cool areas of out nation. Is the even possible? I mean I live in an area that sees 108+/120+ degree weather in summer could my XJ possibly run at 210 with the a/c full blast, at idle, and in stop and go traffic? I want to here from people who have an XJ and who live in areas that see 108+ degree weather. I want to know your engine temps with the a/c on full blast, at idle, and in stop and go traffic. I don't think Jeep designed our cooling systems to run properly at all. Let alone in 108+ degree weather. So let me have your numbers. Oh and if you have any I mean any cooling upgrades please be sure to include them (all of them) with your temp numbers. I'm eager to see what numbers ya'll have. Thank You
hshark is offline
post #2 of 25 Old 06-16-2013, 05:27 AM
Glavus
My Jeep runs at a solid 200F and about 197-198F with the heat on. Bone stock cooling system.
Glavus is offline
post #3 of 25 Old 06-16-2013, 08:26 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm in Arizona with 3 XJs. All have the Mopar stat 83501426AC. Run at 200 to 210 in the summer and warm up quickly in the winter when it's in the 20s.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 25 Old 06-16-2013, 08:27 AM
habbyguy
My XJ runs just under 200 degrees all summer here in the Phoenix area, where afternoon temperatures regularly hit 110-115 (and that doesn't include the extra heat you get on the road surface). I've never had any overheating issues, even with the A/C running full blast (continually), on the hottest days in stop-and-go traffic. I do have a five speed, not an automatic, so there's less heat to deal with using my stock cooling system (with new pump, OEM-style replacement radiator, and new thermostat though).
habbyguy is offline
post #5 of 25 Old 06-16-2013, 09:31 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
At minus 30 degrees in winter, my XJ's warm up to 195*. At 95*+ on a summer day, with the A/C on they run at about 210*. In stop an go summer traffic and on the 4x4 trails, the e-fan runs more often.
Over heating is caused by a lack of routine maintenance of the cooling system. Coolant, hoses, thermostats, water pumps, and radiators need to be service on a regular schedule, and replaced when they wear out.
CJ7-Tim is offline
post #6 of 25 Old 06-16-2013, 10:13 AM
M35A2
1995 XJ Cherokee
We see 100 plus here, only had the truck long enough to go through a week of hot weather, and the temp runs 200-210 on the freeway with the A/C on , the temp creeps up to 215 after a long freeway run and get into stop and go, but it comes back down to the 200-210 after a bit. In slow off road conditions in 95-100 degree temps, (29 Palms a month ago), it stays around the same with the A/C on. The system has been flushed, and new hoses and a stant stat installed. I plan on installing a 3 row BTR, a new w/p and a Mopar stat before our next trip out to the southern deserts this fall.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #7 of 25 Old 06-16-2013, 04:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I like your plan. Consider a water pump?
Do you have an M35A2?
post #8 of 25 Old 06-16-2013, 05:30 PM
aircruiser
aircruiser's Avatar
My beater 98 sees around 210 but gets a little hot wheeling. My 96 sits around 205-210 but I need to replace the radiator since its cracked and when I do that I will be doing upper and lower hoses along with a thermostat. It has no A/C tho.
aircruiser is offline
post #9 of 25 Old 06-16-2013, 07:59 PM
djb383
Since u have a OBD-II XJ ('96), borrow/buy a scan tool and plug it into the ALDL port under the dash. You will then see actual/real coolant temps, and how widely they can vary, under all kinds of different driving conditions, including using/experimenting with different temp t-stats. All kinds of variables raise/lower coolant temp that are probably not accurately reflected by the factory gauge. Only problem is, knowing the truth might scare u. (and no, in 108+ ambient, stopped long periods in traffic, running a/c, with a stock cooling system in perfect/new condition, it ain't gonna run 210)
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #10 of 25 Old 06-16-2013, 09:24 PM
AZ Jeff
2014 JK Wrangler
My XJ will run 200 or a bit less until the ambient gets over 105. Then the temps rise so the needle is about 1/2 a needle width past 200, which I guess to be about 210-215. Speed makes almost no difference.
Of course, this is with the AC running, as only a masochist runs around PHX in a closed car with no AC.
I have a Chrysler OEM thermostat, an OEM water pump, and a CSF three row rad.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #11 of 25 Old 06-17-2013, 03:41 AM Thread Starter
hshark
djb383, I think you fallow what I'm trying to say here. I always see threads where people say they run at 210 no matter what. Though I believe some XJ's run at 210 no matter what where are the XJ's that run a little past 210 on really hot days with heavy loads i.e. a/c, traffic, etc.? I also think as you stated a scan tool is needed. For example I have dual electric fans and run 210 with the a/c on at idle in 108+ degree weather. I left my XJ running for about twenty minutes (in the said conditions) and shut it off. Came back maybe five minutes (or less) later and temp Jumped to 225-230ish and stayed there. Now are the gauges always objective? Are they subjective? Though I agree that coolant gets hotter after shutdown a whole 15-20 degrees in less than 5 minutes seems weird to me. I also read somewhere that the location of the temp switch on the back of the head is a bad area and could provide false readings. I'm unsure of what to make of that, but it's been posted and talked about. I've also read that XJ's like to run 220 with a/c and other load factors. My entire cooling system is new and 210 seems about right, but a little over 210 also seems about right in extreme weather and high load.
hshark is offline
post #12 of 25 Old 06-17-2013, 06:47 AM
M35A2
1995 XJ Cherokee
W/P is in the plan when the radistor swap happens.
I did have a deuce, but with Ca emissions the way they are for trucks, that"s what I do for a living, a mechanic for Cummins Engine Co, 25 years worth, Even though it was registered historic, my gut just said sell now 'cause the great and powerful CARB can and will change their mind and look at a 26000 lb GVW diesel powered truck and say, nope, no registration for you in this state! I didn't want a 26k paper weight in front of my house. It's in my profile if you wana see it.
As for the temp rising after the engine is shut off, that's normal heat soak. It should however come back down to your "normal" operating temp as soon as you put some air flow across the core.
M35A2 is offline
post #13 of 25 Old 06-17-2013, 07:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I had an M543-A1 military wrecker crane for years. Used it in my towing business.
post #14 of 25 Old 06-17-2013, 10:25 AM
djb383
We use a digital ScanGauge in our XJ and also have them/move them to 4 other OBD-II vehicles. The other vehicle's temp gauges only have a "C" and "H" on their temp gauges, no numbers as XJ factory gauges have. On the other vehicles, the temp gauge needle always points +/- the middle. With the ScanGauge, it's easy to see a 10-20 rise/drop in coolant temp but the needle on the factory gauge always points to +/- the middle as long as coolant temp is with-in parameters. Something as simple as changing driving direction 180 degrees (going into wind or going with the wind) can be seen with the ScanGauge, but probably not on a factory temp gauge.
djb383 is offline
post #15 of 25 Old 06-17-2013, 12:04 PM
CoyoteHunter
My 99XJ with 179,xxx miles stays pretty near 210-215 in normal traffic and drops to 200 @ 50mph+
I'm getting temp creep at hot idle due to my e-fan bearings wobbling. I searched the whole U-pull-it on Sat. for a replacement and 95% of the XJs had them removed.LOL The ones that remained were pretty seized up.
I flushed my rusty brown coolant Saturday night and am running some prestone 3-6 hour cleaner now. WP , T-stat, and rad. cap are probably in order!
Thinking about a B&M (70266) trans cooler too. Found one new-in-box for $50.
CoyoteHunter is offline
