Quantcast 1 leaky fuel injector... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1 leaky fuel injector...
Old 01-24-2007, 03:22 PM   #1
RamboPants
1987 XJ Cherokee
I have this one fuel injector that keeps leaking. this is the 2nd time i have changed the orings and its the same one still leaking it leaks just as much as it did before i replaced the o rings. Sometimes my jeep won't start and I'll go move that 1 injector around then it will start. Is that a sign of a bad or clogged injector?
RamboPants is offline   Reply With Quote
Old 01-24-2007, 04:10 PM   #2
RamboPants
1987 XJ Cherokee
Oh also can you buy those little wire like clips that hold the connectors on?
Old 01-24-2007, 05:35 PM   #3
tangofox007
If the injector itself is leaking, a truckload of new o-rings won't help.
tangofox007 is offline   Reply With Quote
Old 01-24-2007, 06:13 PM   #4
bee guz
Go to the yard of junk and get a injector, there are lots of them in the junkyard, maybe they will charge you 5 bucks...
bee guz is offline   Reply With Quote
Old 01-24-2007, 08:10 PM   #5
RamboPants
1987 XJ Cherokee
I'll try the junkyard
Glock Forum
