01 XJ, front driver door lock issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 01 XJ, front driver door lock issues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 03-30-2014, 12:42 PM   #1
ParkerXJ
Having some issues with my 01 xj
104k on the clock
Recently installed 2 12"infinity subs and an alpine sub
Then replaced the front door speakers with 6 1/2" kicker speakers
Hooked everything back up, the passengers door locks fine, but the drivers doesnt
Wont even lock manually, with the remote lock thing, or any other way
Its odd, ive gone in and snugged the connections up with the locking and latching rods (connected to the back of the handle running from inside-out) and that seemed to lock the door only when the door was closed
Any ideas, im stumped
Also, pressing the switch (on the actual handle inside, not the power one for all doors) its stiff and hard to move and even that doesnt lock it
2001 Jeep Cherokee XJ Limited -STOCK
ParkerXJ is offline   Reply With Quote
Unread 03-30-2014, 08:46 PM   #2
ParkerXJ
Anyone?
Unread 04-02-2014, 10:40 PM   #3
uberxj92
1992 XJ Cherokee
It sounds like maybe you bent the rod.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline   Reply With Quote
Unread 04-02-2014, 10:55 PM   #4
ParkerXJ
Ive pulled it two or three times now
Last time I worked, I just set it back a maybe quarter inch, and left out the top bolt just under the tweeter location, and one in the handle, so ive got those 3 main big screws in the arm rest holding it on
It seemed like those pulled it forward just enough to mess it up
So its worked like that so far (3-4days)
Which is really odd
I checked the rods, theyre not bent, and thick and im curious as to how id bend it
Unread 04-02-2014, 11:07 PM   #5
uberxj92
1992 XJ Cherokee
I've bent mine just trying to snap them back in the plastic holder.
Unread 04-02-2014, 11:11 PM   #6
ParkerXJ
Huh, maybe I did then
I dont know, its fixed currently
So im happy with it hah
