01 losing coolant - JeepForum.com
post #1 of 14 Old 03-13-2017, 05:51 PM Thread Starter
myXJrocks
Newbie
myXJrocks's Avatar
01 losing coolant
So maybe someone here has had similar experiences? I have an 01 sport I bought with low miles (130k, low for an 01). It had blew a radiator hose and sat for 2 years. After new hoses, radiator, water pump, thermostat, and heater core, I was still losing coolant. It took dropping the trans to see the leaky freeze plug. Ouch! I finally thought I'd solved the mystery. But not yet. The 4.0 still goes thru a LOT of coolant. No sign of anything wet. The oil shows no water. Could I have a cracked block and be burning a quart of coolant every hundred miles. The motor never misses a beat, no misfiring...troubling!
myXJrocks is offline
post #2 of 14 Old 03-13-2017, 06:02 PM
caronaxtr2
When you check your coolant it's not creamy or milky is it? 2000 & 2001 have a history of getting cracked heads. I had an 01 for 5 years and had no problems with it, but it is a known issue.
Build:
caronaxtr2 is offline
post #3 of 14 Old 03-13-2017, 06:06 PM Thread Starter
myXJrocks
Newbie
myXJrocks's Avatar
No, oil is clean and it doesn't use any. I had the head tested and new gasket also. That's why I'm puzzled.
post #4 of 14 Old 03-13-2017, 06:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The coolant isn't disappearing, it is leaking, either from the cooling system, externally from the head gasket, or internally to the cylinders and out the tail pipe.
You replaced one freeze plug, or all of them ? Have you performed a cylinder leak down test ? Have you performed a cooling system pressure test ? Have you had the oil analyzed ?
CJ7-Tim is offline
post #5 of 14 Old 03-14-2017, 06:11 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
That's exactly what my 00' XJ did when the head had a small crack. When it gets worse, the coolant will show up in the oil.
TheBoogieman is offline
post #6 of 14 Old 03-14-2017, 07:01 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Do research on CRACKED 0331 CYLINDER HEAD + JEEP CHEROKEE On all XJ forums and also just using a simple Google search. There are literally hundreds of threads on it, so no need to reinvent the wheel here.
I'm not saying that is your issue, but it sure could be and as an owner of a 2001 XJ, it's imperative that you understand it.
Good luck and keep us updated!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #7 of 14 Old 03-14-2017, 08:40 AM
bluejunior
bluejunior's Avatar
Send your oil in to Blackstone. $30 and they'll test it for coolant traces. Way easier and cheaper than trying to pull the head off and have it fluxed again or something.
Unfortunately it's almost impossible to get any response other than ITS THE HEAD on any forum once you admit 00-01 so you might as well cross it off the list.
Also:what's the state of your rad cap? When my last one went it pretty much just let a constant drip of coolant out any time the jeep was warm and revving. Dripped right out of the bay and didn't show under idle. Took me ages to spot and my threads were all met with cries of 0331.
Lifted, Locked, Stiffened
bluejunior is online now
post #8 of 14 Old 03-14-2017, 08:48 AM
ou2mame
I've got a few slightly leaking side freeze plugs that drip to the rms area. If it's leaking externally it would be on the ground. Could be a hg into the Cyl, or cracked head. They still test kits at auto stops too to test for making hg
Sent from my HTC M9 using Tapatalk
ou2mame is offline
post #9 of 14 Old 03-14-2017, 11:06 AM
axlaxl
Also:what's the state of your rad cap? When my last one went it pretty much just let a constant drip of coolant out any time the jeep was warm. Took me ages to spot and my threads were all met with cries of 0331.
What he said.
Blackstone to rule out cracked head and get a good insight into your engine health.
Pressure test the cooling system like CJ7 Tim said.
axlaxl is offline
post #10 of 14 Old 03-15-2017, 05:20 PM Thread Starter
myXJrocks
Newbie
myXJrocks's Avatar
Right. I've just begun to learn about the 00-01 head. Originally it was gone thru and pressure tested. I've gotten tired of chasing this. Found a 98 block and we're going to freshen it up. I've been told an 03 and up head is built better and will be a direct replacement. We will do a 3 angle valve job and put it all together. This is the wife's toy so I need it all to run smoothly. My 01 will be next.
post #11 of 14 Old 03-15-2017, 05:38 PM
bluejunior
bluejunior's Avatar
03+ WJ or TJ 4.0 heads are a direct
03+ TJ or WJ 4.0 heads are a direct replacement without the cracking issue. Technically 02.5+ works but you have to look for the "TUPY" stamp under the fill cap on the valve cover to be sure.
99- heads can be made to work, but you have to drill and tap mounting points for the spark rail since they had a distributor rather than the coil on plug design of 00+
You can also order one from Clearwater, more expensive than a JY unit, though. Hopefully that clarifies your search.
The 30ish bucks for Blackstone might be worth it to save you rebuilding an engine if you think it isn't cracked yet, or if you're going to rebuild anyway you might check out the budget stroker builds on Dino's 4.0 performance site if you're putting in a bunch of labor anywa and have some cash.
post #12 of 14 Old 03-15-2017, 10:49 PM
ArmyStrongMD
I wouldn't rule out something else in the system. Have you done the radiator and all hoses? I had a pesky coolant leak in my 00 that turned out to be somewhere in the radiator. I was terrified of the head issue but replacing the radiator and hoses fixed it for me.
Interesting about the oil test...will have to try that anyway to see if I have a minor head crack but she doesn't go through coolant anymore that I have been able to tell.
ArmyStrongMD is offline
post #13 of 14 Old 03-16-2017, 10:48 AM Thread Starter
myXJrocks
Newbie
myXJrocks's Avatar
Thanks to everyone who has given advice. I am new to the forum and am already seeing the benefit of hearing from people with years of experience, where I am just a "newbie". I will be a member for a long time...
post #14 of 14 Old 03-17-2017, 03:16 PM
Rob K
1995 XJ Cherokee
See if you have a parts store by you that will rent you a cooling system pressure tester. I rented one at Oreillys before I bought one. Connect it to the radiator, pressurize the system, check for leaks. Often they only show up with the system pressurized. If you do have the cracked head you may even be able to see coolant seeping out the crack between cylinders three and four by looking down the oil fill hole in the valve cover.
Rob K is offline
