01 ignition coil replacement info - JeepForum.com
post #1 of 17 Old 03-10-2009, 07:53 PM Thread Starter
spencer411hire
im pretty sure i need to replace one of the ignition coils on my 01 and i dont have any info.
i did a search that did not yield any results.
i have replaced the plugs before and am familiar with taking off the ignition strip, but dont remember paying much attention to the coils.
any help is appreciated.
spencer411hire is offline
post #2 of 17 Old 03-10-2009, 08:24 PM
01sherman
the whole strip wold have to be replaced theres no replacing just one coil you can get a coil strip from any autoparts store for about 165
01sherman is offline
post #3 of 17 Old 03-10-2009, 09:44 PM Thread Starter
spencer411hire
might as well change the plugs while im at it eh?
post #4 of 17 Old 03-10-2009, 09:50 PM
filluptrk
Why do think you need to replace the unit? Phil
filluptrk is offline
post #5 of 17 Old 03-10-2009, 10:10 PM Thread Starter
spencer411hire
i can tell its not firing on all of em
rough idle
plus i had a friend pull the code with a meter
post #6 of 17 Old 03-10-2009, 10:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What were the codes that you pulled?
Misfires can have a number of different causes. Before you open the hood and start throwing money into a dark hole, maybe you should do some thorough and logical diagnostic troubleshooting.
CJ7-Tim is offline
post #7 of 17 Old 03-10-2009, 10:51 PM Thread Starter
spencer411hire
well i was kind of wanting to just replace the coils anyway as well as plugs
i dont know exactly what the code was as it wouldnt make any sense to me, but i do understand there could be other reasons for the misfires. we are looking into all options
were there any write-ups/stickeys about changing the ignition strip that i missed?
thanks
post #8 of 17 Old 03-10-2009, 11:00 PM
CJ7-Tim
CJ7-Tim's Avatar
The coil rail is not replaced unless it has failed. $165 is a lot of money to spend on something that isn't broken.
If the codes are still in the ECM use a code scanner and then write them down. There are lists of trouble codes on the Internet that you can use to make logical choices of which parts to test and which may need replacement.
CJ7-Tim is offline
post #9 of 17 Old 03-10-2009, 11:07 PM Thread Starter
spencer411hire
my buddy knows the code and we will def look into that more
this sounds exactly like the problems im having
http://www.justanswer.com/questions/...e-4-0-6-having
just seems like a tune-up is in order and if that means replacing the rail then so be it
post #10 of 17 Old 03-10-2009, 11:21 PM
CJ7-Tim
CJ7-Tim's Avatar
The spark plugs should be replaced every 2 years or 30,000 miles as recommended by the owners manual. Nearly everyone on this forum will tell you that SplitFire type and Platinum type premium spark plugs are a waste of money and can even cause misfires. The basic Champion park plug is the one the runs best in the Jeep 4.0L.
Misfires can be caused by a dirty throttle body, dirty injectors, loose engine or battery wires, a malfunctioning CPS, TPS or CKP, or bad gasoline. Simple maintenance items that are inexpensive and easy to perform should be the first things on your list.
CJ7-Tim is offline
post #11 of 17 Old 03-11-2009, 05:58 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Your best bet would be to get the actual codes and post here for comment.
Don't replace that coil rail just yet......as Tim mentions, it generally is not replaced as a matter of course unless other things have been eliminated.
A new set of plugs should absolutely be installed (champions) as one of the first things to try. Not that it couldn't be the coil rail but basic stuff first.
Posting codes and replacing plugs would be a good start to a methodical process of elimination here....
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #12 of 17 Old 03-11-2009, 03:48 PM Thread Starter
spencer411hire
im well aware that the splitfire and platinum (bosch etc.) arent worth the cash. ive have always used NGKs and have had nothing but quality performance from them. they are just about 2 years old now and they are getting changed regardless of what i do about the misfires
thanks for the help!
post #13 of 17 Old 03-11-2009, 03:51 PM Thread Starter
spencer411hire
im going to do exactly that
ill post the code
thanks!
post #14 of 17 Old 03-11-2009, 03:53 PM Thread Starter
spencer411hire
ok so the code is "P0301"
and this description is almost exaclty like what is goin on
in fact the check engine light went off last night
post #15 of 17 Old 03-11-2009, 05:32 PM
tjwalker
tjwalker's Avatar
P0301 is a cylinder #1 misfire.
Gotta change out that plug at a minimum and see if that eliminates the light and symptoms.
Another thing that is specific to a single cylinder misfire would be a faulty fuel injector. If a new plug doesn't resolve the problem, I'd check the resistance on the fuel injector and compare the readings to other injector resistance readings.
tjwalker is offline
coil and ignition romeo_zooloo MJ Comanche Technical Forum 2 04-16-2008 11:59 AM
coil and ignition romeo_zooloo MJ Comanche Technical Forum 0 04-16-2008 07:28 AM
ignition coil Fulk1204 XJ Cherokee Technical Forum 6 04-12-2007 01:45 PM
Ignition Coil Replacement cfkingfish XJ Cherokee Technical Forum 3 03-16-2004 11:12 AM
Ignition coil mbood82 XJ Cherokee Technical Forum 6 12-01-2003 09:54 AM
