01 Coolant Reservoir - JeepForum.com
post #1 of 7 Old 12-17-2006, 08:01 AM Thread Starter
Gr8Swammee
Gr8Swammee's Avatar
Howdy all.
I have an 01 Classic, and I've com across a crack at the seam on my coolant reservoir. It's right at the top ad is about a half inch long. Now I've never overheated and I don't think it's been there for that long, but I wa wondering if i could fix it with some JB weld, or if i need to replace it. Is the overflow reservoir a pressurized area that needs a proper seal?
Gr8Swammee is offline
post #2 of 7 Old 12-17-2006, 08:16 AM Thread Starter
Gr8Swammee
Gr8Swammee's Avatar
post #3 of 7 Old 12-17-2006, 08:18 AM Thread Starter
Gr8Swammee
Gr8Swammee's Avatar
post #4 of 7 Old 12-17-2006, 08:19 AM Thread Starter
Gr8Swammee
Gr8Swammee's Avatar
ok upon closer inspection it's about an inch long
post #5 of 7 Old 12-17-2006, 08:31 AM
AZ Jeff
2014 JK Wrangler
Don't use JB Weld, as the flexible nature of the recovery tank will make the JBWeld want to separate from the tank.
Clean the area with sandpaper and some degreaser, and repair the crack with RTV Silicone rubber.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 7 Old 12-17-2006, 09:17 AM
GPTH1NG
GPTH1NG's Avatar
I had to replace mine awhile back because something sharp on the body where it was resting poked a hole in the bottom of it. It was less than $20 and the only extra thing I needed was a tiny clamp for the hose.
01 Cherokee Sport
Amber Fire
ORANGE Jeep Club Member #3
04 Wrangler X
GPTH1NG is offline
post #7 of 7 Old 12-17-2006, 09:47 AM Thread Starter
Gr8Swammee
Gr8Swammee's Avatar
ahh good to know!I was expecting a small plastic reservoir from the stealership to be like 90 bucks... i bought some clear rtv silicone adhesive/sealent from autozone, if ti doesn't work i'll poney up the money. thanx for the help!
Washer Fluid in Coolant Reservoir 98XJinME XJ Cherokee Technical Forum 4 10-11-2009 10:21 PM
4.0 seems to be leaking... coolant reservoir depletes cherocon XJ Cherokee Technical Forum 6 02-08-2009 08:24 PM
Coolant reservoir empty missyxj XJ Cherokee Technical Forum 10 12-02-2008 06:53 AM
Rust in the coolant reservoir wizardPC XJ Cherokee Technical Forum 7 04-17-2007 08:26 PM
Expansion reservoir - coolant trashman XJ Cherokee Technical Forum 14 03-06-2005 10:07 PM
