'01 Cherokee o2 sensor/engine wiring diagram? - JeepForum.com
post #1 of 3 Old 05-03-2013, 08:19 AM Thread Starter
Bullitt4113
Does anyone here have a diagram of the '01 engine wiring harness where the o2 sensor wires run into the harness? I've got a P0161 code for bank 2, sensor 2 and I've got a new o2 to replace it, but I'd also like to check out all the wiring leading up to the harness to make sure that is all ok as well.
2001 Silverstone Metallic Cherokee Classic, 4.0 AW-4, BFG All-Terrains, 50% tint, more to come!
2001 Ford Mustang Bullitt - Intercooled Novi 2000, MM coilovers, built IRS, Bilstein HD's, Borla Stingers, etc.
Bullitt4113 is offline
post #2 of 3 Old 05-03-2013, 01:03 PM
CCKen
CCKen's Avatar
Until such time as I get your diagrams uploaded to my Photobucket and posted here, you can do a check of the O2S heater element.
The two White wires coming from the O2S are the heater circuit withn the O2S. With the O2S at room temp and using an Ohmeter, measure the resistance between the two White wire pins on the O2S connector. A serviceable heater element will read between 4.0 and 7.0 Ohms.
You can also check the ground circuit for the O2S by measuring the resistance in the O2S body harness connector (Pin 2) Black wire to engine structure ground. The resistance should be no more than 5.0 Ohms.
The O2s Heater ground point is at the right front of the engine block, near the alternator. The battery also grounds here (two studs on the engine block).
There's no easy way (but it can be done) to check to see if you have power to the O2S heater (Pin 1) Violet/Orange tracer wire) so I won't get into it.
Note the time of my posting; that's beer time hereabouts. I'll check back later.
Cheers
CCKen is offline
post #3 of 3 Old 05-03-2013, 01:31 PM Thread Starter
Bullitt4113
Cheers
Haha, almost that time here too
Thanks for the info, I'll do some investigating tomorrow morning
