01 Cherokee Interior Lights stuck on - JeepForum.com
post #1 of 11 Old 08-05-2010, 12:04 PM Thread Starter
klwong1
When the keyless entry is used the interior lights come on and stay on. They only way to get them to go off is to pull the fuse or disconnect the battery. Any ideas of where to start?
klwong1 is offline
post #2 of 11 Old 08-05-2010, 12:12 PM Thread Starter
klwong1
Okay, now they are stuck on period. I've already changed out the door jamb switches and dimmer switch. Checked the rear hatch switch too.
They stay on even when the car is started and the doors are shut. I pulled the fuse for the keyless and they shut off. Right now I just took out the dome lights until I can fix it.
Do you think its the keyless entry system? Where is that located?
klwong1 is offline
post #3 of 11 Old 08-05-2010, 12:37 PM
Smuggled_Rice
Interior lights
Are you sure the headlight switch/dash light dimmer isn't turned all the way to the right?
XJ HID Bi-xenon Projector Retrofit:
http://www.jeepforum.com/forum/f11/xj-hid-bi-xenon-projector-retrofit-985343/
Smuggled_Rice is offline
post #4 of 11 Old 08-05-2010, 02:14 PM Thread Starter
klwong1
Yup, that was the first thing checked and it was not it.
klwong1 is offline
post #5 of 11 Old 08-05-2010, 02:41 PM
AZ Jeff
2014 JK Wrangler
Door switches complete the GROUND for the interior lights. I would bet you have a short in the wiring from the dome light to ground.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 11 Old 08-05-2010, 03:11 PM
Ben
This.
The cargo light switch, and door switches, are parallel grounds. Sounds like somewhere in that loop, you have a wire that's taken a short.
Unplug the cargo light. That will isolate that part of the grounding loop at least.
It very well could be a wire crimped, in one of the soft boots, running to any one of the doors... most likely, the one that gets opened the most.
Ben is offline
post #7 of 11 Old 08-06-2010, 10:41 AM Thread Starter
klwong1
Where is the keyless entry module located? I have read a couple places that it was the cause of this problem as well, but could not find where it is located.
klwong1 is offline
post #8 of 11 Old 08-06-2010, 12:15 PM
TheNerd
TheNerd's Avatar
The circuit board is located in the overhead light assy (the forward most one) if you don't have an overhead console, and in the overhead console if you do have one.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #9 of 11 Old 03-10-2011, 07:35 PM
XJKyle1389
reviving an old thread. I have this same problem on my 1998 XJ. My dome lights are always on. If I unplug the overhead console the courtesy lights go off BUT the rear hatch and front floorboard lights remain on. I havent a clue. I DID CHECK THE DIMMER SWITCH, please dont ask if I had. All door switches have been tested, and jumpered for testing. All are OK. Your input is greatly welcomed. Thank you.
1998 XJ classic, 4.5in lift, glasspack exhaust, more to come....
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
XJKyle1389 is offline
post #10 of 11 Old 03-10-2011, 08:54 PM
EdgarS
Have you checked the rear light switch? sometimes it gets stuck as if the hacth was open and makes the lights stay on.
98muddyjeep: mine makes noise when shes parked.she used to purr like a kitten now its more like a 16 y/o asmatic cat in liver failure.
EdgarS is offline
post #11 of 11 Old 03-14-2011, 12:43 PM
XJKyle1389
checked and its off.
_=====o000o
92 Cherokee Power Locks/Interior Lights Died GAN XJ Cherokee Technical Forum 11 12-08-2015 01:33 PM
Interior lights stuck on? CallMeColt XJ Cherokee Technical Forum 13 08-29-2009 09:45 AM
98 Interior lights stuck on!!!!! o_skiii XJ Cherokee Technical Forum 2 05-25-2009 09:33 PM
Interior Dome Lights Stay On - '96 Cherokee Country sisham XJ Cherokee Technical Forum 4 04-03-2008 01:15 PM
HELP-Which fuse controls interior lights 2000 cherokee Astorm XJ Cherokee Technical Forum 2 07-11-2005 06:56 AM
